  • Dayton Audio DMPC-8.2 8.2uF 250V Polypropylene Capacitor
Dayton Audio
Part #027-426
Dayton Audio
Part #027-426
Model: DMPC-8.2
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 20 mm x 46 mm
Your Price: $2.29
MSRP: $5.99
Save $3.70 (62%)
Quantity:Qty: 1-9 $2.29/ea
Quantity:Qty: 10+$2.06/ea
808In Stock
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 8.2 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 20 mm Dia. x 46 mm L.
ModelDMPC-8.2
Part Number027-426
UPC844632013799
Weight0.032
Capacitance8.2 uF
Tolerance5%
Voltage Rating250V
