  • Dayton Audio DMPC-33 33uF 250V Polypropylene Capacitor
Dayton Audio
Part #027-441
Dayton Audio
Part #027-441
Model: DMPC-33
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 33 mm x 61 mm
Your Price: $6.67
MSRP: $18.99
Save $12.32 (65%)
49In Stock
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 33.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 33 mm Dia. x 61 mm L.
ModelDMPC-33
Part Number027-441
UPC844632067235
Weight0.12
Capacitance33 uF
Tolerance5%
Voltage Rating250V
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
