  • Dayton Audio DMPC-6.8 6.8uF 250V Polypropylene Capacitor
Dayton Audio
Part #027-424
Dayton Audio
Part #027-424
Model: DMPC-6.8
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 18 mm x 45 mm
Your Price: $1.89
MSRP: $5.99
Save $4.10 (68%)
Quantity:Qty: 1-9 $1.89/ea
Quantity:Qty: 10+$1.71/ea
Order in the next 11 hr 18 min to ship today. Details
2090In Stock
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 6.8 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 18 mm Dia. x 45 mm L.
ModelDMPC-6.8
Part Number027-424
UPC844632013782
Weight0.01
Capacitance6.8 uF
Tolerance5%
Voltage Rating250V
