  • Dayton Audio BPA-38G HD Binding Post Banana Jack Pair Gold
Dayton Audio
Part #091-1245
Dayton Audio
Part #091-1245
Model: BPA-38G
Superior design, materials, and construction, at a sensible price—the Dayton Audio BPA-38G heavy-duty binding post pair is the low cost/high fidelity option!
  • 24kt. gold plating for best signal transfer and corrosion resistance
  • 1-1/2" rear bolt mounts in speaker cabinets from 3/8" to 1" thick
  • Large diameter knurled heads enable positive finger-tight connections
  • Knurled shaft prevents post rotation
Your Price: $9.98
MSRP: $11.99
Save $2.01 (17%)
Quantity:Qty: 1-9 $9.98/ea
Quantity:Qty: 10+$8.98/ea
The Dayton Audio BPA-38G heavy-duty binding posts were designed with the audiophile in mind. Quality, 24kt. gold plating assures the highest possible signal transfer and resists harsh environmental conditions that cause performance-robbing corrosion. The BPA-38G binding posts can be used with banana plugs or will accept wire up to 8 gauge, and large diameter knurled heads allow positive finger-tight connections.
An extra long rear bolt (1-1/2") facilitates mounting in speaker cabinets with walls up to 1" thick (3/8" minimum thickness). To install, simply drill a 1/4" hole and gently tap the binding post in place. The knurled shaft will keep the post from turning, and also creates an air-tight fit. Overall length is 2-1/4". Sold in color coded pairs with solder tabs.
ModelBPA-38G
Part Number091-1245
UPC844632018459
Weight0.16
Contact PlatingGold
Style / TypeSingle
