Dayton Audio DMPC-100 100uF 250V Polypropylene Capacitor
- 250 VDC rating
- 5% tolerance
- High purity
- High current capacity
- Specially designed for crossovers
- Dimensions: 51 mm x 75 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers. Large values are great for 3-way speaker designs.
• Value: 100.0 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 51 mm Dia. x 75 mm L.
Product Details | |
Brand | Dayton Audio |
Model | DMPC-100 |
Part Number | 027-447 |
UPC | 844632016356 |
Unit of Measure | Each |
Weight | 0.25 |
Product Specifications | |
Capacitance | 100 uF |
Tolerance | 5% |
Voltage Rating | 250V |
