Dayton Audio DMPC-0.22 0.22uF 250V Polypropylene Capacitor
- 250 VDC
- 5% tolerance
- High purity
- High current capacity
- Specially designed for crossovers
- Dimensions: 7 mm x 18 mm
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 0.22 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 7 mm Dia. x 18 mm L.
Product Details | |
Brand | Dayton Audio |
Model | DMPC-0.22 |
Part Number | 027-402 |
UPC | 844632013676 |
Unit of Measure | Each |
Weight | 0.005 |
Product Specifications | |
Capacitance | 0.22 uF |
Tolerance | 5% |
Voltage Rating | 250V |
