  • Dayton Audio DMPC-7.5 7.5uF 250V Polypropylene Capacitor
Dayton Audio
Part #027-429
Dayton Audio
Part #027-429
Model: DMPC-7.5
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications.
  • 250 VDC
  • 5% tolerance
  • High purity
  • High current capacity
  • Specially designed for crossovers
  • Dimensions: 20 mm x 45 mm
Your Price: $2.19
MSRP: $5.99
Save $3.80 (63%)
Quantity:Qty: 1-9 $2.19/ea
Quantity:Qty: 10+$1.97/ea
923In Stock
Make the Dayton Audio line of metallized polypropylene capacitors your standard choice for all of your loudspeaker projects! The same high quality as the competing brands ... but at a much lower price. They are suitable for a wide range of applications. They are ideal for use in loudspeaker crossover networks, or for by-passing large value non-polarized electrolytics. Also a good choice as coupling capacitors in the signal path of audio power amplifiers and preamplifiers.
• Value: 7.5 µF
• Rated: 250 VDC
• Tolerance: ±5%
• Dielectric Strength: 150%
• Dimensions: 20 mm Dia. x 45 mm L.
ModelDMPC-7.5
Part Number027-429
UPC844632014659
Weight0.12
Capacitance7.5 uF
Tolerance5%
Voltage Rating250V
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
