  • Dayton Audio Pro 15 in. 8 Ohm Neodymium Midbass Woofer Odeum 15N
Dayton Audio
Part #295-643
Dayton Audio
Part #295-643
Live sound is back in business! Dayton Audio wants you to hit the road with confidence and maximize your profitability at your next gig. Dayton Audio is a worldwide leader in raw frame drivers. We are passionate audio enthusiasts with a vision to offer the best performance to price value in the industry. After extensive market research, vendor evaluation, and sample driver testing, we are proud to introduce to you the Dayton Audio ODEUM Series.
  • Powerful neodymium motor for superior output.
  • Copper inductance cap for low distortion
  • Paper cone and cloth m-roll surround for high clarity, smooth response, and linear excursion for pounds of punch
  • 3” Inside/outside wound copper voice coil leads on fiberglass former lends solid power handling capability
  • Under spider and rear periphery venting allow for a cooler running voice coil
  • Low Qts means high damping and smaller boxes
  • With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise. We stand behind our products and our warranty is a demonstration of our commitment to quality and reliability.
Your Price: $152.98
MSRP: $289.99
Save $137.01 (47%)
62In Stock
ode· um | \ ō-ˈdē-əm: An ancient Greek and Roman concert hall used for music and poetry.
Using the knowledge from decades of driver design and engineering, Dayton Audio is placing an emphasis on technical excellence, product reliability, and innovation with the Odeum Series of speaker components! The Odeum Series takes the stage with a new line of professional drivers made for any venue.
Key Specs:
  • Nominal Diameter: 15"
  • Power Handling (RMS): 500 Watts
  • Power Handling (MAX): 1000 Watts
  • Impedance: 8 Ω
  • Frequency Response: 40Hz - 4.5kHz
  • Sensitivity: 98.6 dB 2.83V/1m
  • Voice Coil Diameter: 3"
  • Maximum Linear Excursion: 6.55mm
    Frequency Response & Impedance
    The Dayton Audio Pro 15 has a response that matches a large number of horn drivers and tweeters due to its high efficiency in the frequency range of human voices and midrange detail of stringed instruments. The impedance curve of the Apollo 15 makes it easy to pair up with your favorite compression driver without taxing your power amplifiers!
    Dayton Audio Pro 15
    The Dayton Audio Pro 15 is a 15" mid-bass woofer that is guaranteed to outperform the stock woofers in your PA system. A 500W power limit is achieved through the combination of a neodymium motor, a 3" voice coil with a fiberglass former, and a copper inductance cap to lower distortion. A paper cone with cloth M-roll surrounds provides a neutral tone that is easy to tune, and peripheral venting helps keep the whole system cool when playing!
    A solution for every need
    We feel we have hit the sweet spot in price and specs in the pro audio market with this workhorse line of subwoofers, midrange, and high-frequency drivers. The ODEUM series consist of two 1200W 18” subwoofers (one neodymium, one ceramic), 5 sizes and various power ratings of neodymium mid-bass, and two 1” exit compression drivers (one bolt-on, one screw-on). Upgrade, replace, or create a new pro sound system with the ODEUM series.
    We've Got Your Back
    Learn More
    Shop the Whole Odeum Series
    Dayton Audio Pro 6
    Nominal Diameter: 6.5"
    Frequency Response: 90Hz - 8.0kHz
    Shop Now
    Dayton Audio Pro 8
    Nominal Diameter: 8"
      Frequency Response: 75Hz - 5.8kHz
      Dayton Audio Pro 10
      Nominal Diameter: 10"
      Frequency Response: 60Hz - 4.2kHz
      Dayton Audio Pro 12
      Nominal Diameter: 12"
      Frequency Response: 40Hz - 5.6kHz
      Dayton Audio Pro 18F
      Nominal Diameter: 18"
      Frequency Response: 35Hz - 1.0kHz
      Dayton Audio Pro 18
      Ryman 1017S
      Exit Diameter: 1"
      Frequency Response: 1kHz - 20kHz
      Ryman 1017B
      Exit Diameter: 1"
      Model15MB500N-8
      Part Number295-643
      UPC848791008511
      Weight14
      Nominal Diameter15"
      Power Handling (RMS)500 Watts
      Frequency Response40 to 4,500Hz
      Sensitivity98.6dB 2.83V/1m
      Voice Coil Diameter3"
      Resonant Frequency (Fs)44Hz
      DC Resistance (Re)5.8Ω
      Voice Coil Inductance (Le)0.14mH
      Mechanical Q (Qms)10.47
      Electromagnetic Q (Qes)0.34
      Total Q (Qts)0.33
      Compliance Equivalent Volume (Vas)5.46ft³
      Mechanical Compliance of Suspension (Cms)0.142mm/N
      BL Product (BL)20.96T·m
      Diaphragm Mass Inc. Airload (Mms)93.39g
      Maximum Linear Excursion (Xmax)6.55mm
      Surface Area of Cone (Sd)844.53cm²
      Cone MaterialCoated Paper
      Surround MaterialPaper
      Voice Coil FormerFiberglass
      Magnet MaterialNeodymium
      Overall Outside Diameter15.42"
      Baffle Cutout Diameter13.89"
      Depth6.65"
      Sealed Volume1.7ft³
      Sealed F3114Hz
      Vented Volume3.5ft³
      Vented F349Hz
