  • Dayton Audio Pro 15 in. 8 Ohm Subwoofer Odeum 15LF
Dayton Audio
Part #295-648
Dayton Audio
Part #295-648
Live sound is back in business! Dayton Audio wants you to hit the road with confidence and maximize your profitability at your next gig. Dayton Audio is a worldwide leader in raw frame drivers. We are passionate audio enthusiasts with a vision to offer the best performance to price value in the industry. After extensive market research, vendor evaluation, and sample driver testing, we are proud to introduce to you the Dayton Audio ODEUM Series.
  • Robust build quality for years of chest pounding output
  • Well balanced SPL to Xmax ratio equates to a loud and long-throw sub
  • Low Qts and high Bl for small vented enclosures
  • Immense output and low frequency capability for an unbelievable price
  • With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise. We stand behind our products and our warranty is a demonstration of our commitment to quality and reliability.
Your Price: $149.98
MSRP: $259.99
Save $110.01 (42%)
Quantity:Qty: 1-3 $149.98/ea
Quantity:Qty: 4+$139.98/ea
30In Stock
Dayton Audio Odeum Apollo 15LF500-8 15" Professional Woofer
ode· um | \ ō-ˈdē-əm: An ancient Greek and Roman concert hall used for music and poetry.
Using the knowledge from decades of driver design and engineering, Dayton Audio is placing an emphasis on technical excellence, product reliability, and innovation with the Odeum Series of speaker components! The Odeum Series takes the stage with a new line of professional drivers made for any venue.
Key Specs:
  • Nominal Diameter: 15"
  • Power Handling (RMS): 500 Watts
  • Power Handling (MAX): 1,000 Watts
  • Impedance: 8 Ω
  • Frequency Response: 25Hz - 1.2kHz
  • Sensitivity: 96 dB 2.83V/1m
  • Voice Coil Diameter: 3"
  • Maximum Linear Excursion: 9.25mm
Dayton Audio Apollo 15LF
The Dayton Audio Apollo 15LF is an 15" low frequency professional driver that is guaranteed to outperform the stock woofers in your PA system. A 500W power rating is achieved through the combination of a large ferrite motor, a 3" inside-outside wound voice coil with a fiberglass former, and extensive venting to increase power handling and reduce power compression. A treated paper cone with cloth accordion surrounds provides a neutral tone that is easy to tune, and a progressive spider helps keep cone excursion under control.
Built to Blast
The Dayton Audio Apollo 15LF packs a lot of punch in a small package. Up to 3/4" P-P cone excursion lets the 15LF go lower and louder for longer. The large motor demands impressive control and allows a low Qt of 0.26, meaning this will shine in small vented enclosures.
A single 15LF can be used in as little as 3.5 cubic feet in a small footprint, high output design that handles 700 watts and extends into the mid 20's reaching SPL's in excess of 96 dB!
Compare the Apollo LF family of woofers to others in their class and you will see that you can achieve all of the same performance, for as little as half the price of the competition!
We've Got Your Back
Learn More
Shop the Whole Odeum Series
Dayton Audio Pro 6
Nominal Diameter: 6.5"
Frequency Response: 90Hz - 8.0kHz
Shop Now
    Dayton Audio Pro 8
    Nominal Diameter: 8"
    Frequency Response: 75Hz - 5.8kHz
    Shop Now
      Dayton Audio Pro 10
      Nominal Diameter: 10"
      Frequency Response: 60Hz - 4.2kHz
      Shop Now
        Dayton Audio Pro 12
        Nominal Diameter: 12"
        Frequency Response: 40Hz - 5.6kHz
        Shop Now
          Dayton Audio Pro 15
          Frequency Response: 40Hz - 4.5kHz
          Shop Now
            Dayton Audio Pro 18N
            Nominal Diameter: 18"
            Frequency Response: 35Hz - 1.0kHz
            Shop Now
              Ryman 1017S
              Exit Diameter: 1"
              Frequency Response: 1kHz - 20kHz
              Shop Now
                Ryman 1017B
                Exit Diameter: 1"
                Shop Now
                  Model15LF500-8
                  Part Number295-648
                  UPC848791009716
                  Weight22.85
                  Nominal Diameter15"
                  Bolt Circle Diameter14.75
                  Power Handling (RMS)500 Watts
                  Frequency Response25 to 1,200Hz
                  Sensitivity96dB 2.83V/1m
                  Voice Coil Diameter3"
                  Resonant Frequency (Fs)25.5Hz
                  DC Resistance (Re)6.4Ω
                  Voice Coil Inductance (Le)1.74mH
                  Mechanical Q (Qms)6.7
                  Electromagnetic Q (Qes)0.27
                  Total Q (Qts)0.26
                  Compliance Equivalent Volume (Vas)11.7ft³
                  Mechanical Compliance of Suspension (Cms)0.33mm/N
                  BL Product (BL)21.1T·m
                  Diaphragm Mass Inc. Airload (Mms)117g
                  Maximum Linear Excursion (Xmax)9.25mm
                  Surface Area of Cone (Sd)837.4cm²
                  Surround MaterialCloth
                  Voice Coil FormerFiberglass
                  Overall Outside Diameter15.4"
                  Baffle Cutout Diameter14"
                  Depth7"
                  Sealed Volume1.5ft³
                  Sealed F383Hz
                  Vented Volume4.5ft³
                  Vented F339Hz
