  • Dayton Audio Pro 12 in. 8 Ohm Neodymium Midbass Woofer Odeum 12N
Dayton Audio
Part #295-642
Dayton Audio
Part #295-642
Model: 12MB400N-8
Live sound is back in business! Dayton Audio wants you to hit the road with confidence and maximize your profitability at your next gig. Dayton Audio is a worldwide leader in raw frame drivers. We are passionate audio enthusiasts with a vision to offer the best performance to price value in the industry. After extensive market research, vendor evaluation, and sample driver testing, we are proud to introduce to you the Dayton Audio ODEUM Series.
  • Powerful neodymium motor for superior output.
  • Copper inductance cap for low distortion
  • Paper cone and cloth m-roll surround for high clarity, smooth response, and linear excursion for pounds of punch
  • 3” Inside/outside wound copper voice coil leads on fiberglass former lends solid power handling capability
  • Under spider and rear periphery venting allow for a cooler running voice coil
  • Low Qts means high damping and smaller boxes
  • With a Dayton Audio 5 year warranty, it’s more than a guarantee, it’s a promise. We stand behind our products and our warranty is a demonstration of our commitment to quality and reliability.
Your Price: $127.48
MSRP: $259.99
Save $132.51 (51%)
Order in the next 2 hr 48 min to ship today. Details
64In Stock
ode· um | \ ō-ˈdē-əm: An ancient Greek and Roman concert hall used for music and poetry.
Using the knowledge from decades of driver design and engineering, Dayton Audio is placing an emphasis on technical excellence, product reliability, and innovation with the Odeum Series of speaker components! The Odeum Series takes the stage with a new line of professional drivers made for any venue.
Key Specs:
  • Nominal Diameter: 12"
  • Power Handling (RMS): 400 Watts
  • Power Handling (MAX): 800 Watts
  • Impedance: 8 Ω
  • Frequency Response: 40Hz - 5.6kHz
  • Sensitivity: 96.6 dB 2.83V/1m
  • Voice Coil Diameter: 3"
  • Maximum Linear Excursion: 6.75mm
    Frequency Response & Impedance
    The Dayton Audio Apollo 12 has a response that matches a large number of horn drivers and tweeters due to its high efficiency in the frequency range of human voices and midrange detail of stringed instruments. The impedance curve of the Apollo 12 makes it easy to pair up with your favorite compression driver without taxing your power amplifiers!
    Dayton Audio Pro 12
    The Dayton Audio Pro 12 is a 12" mid-bass woofer that is guaranteed to outperform the stock woofers in your PA system. A 400W power limit is achieved through the combination of a neodymium motor, a 3" voice coil with a fiberglass former, and a copper inductance cap to lower distortion. A paper cone with cloth M-roll surrounds provides a neutral tone that is easy to tune, and peripheral venting helps keep the whole system cool when playing!
    A solution for every need
    We feel we have hit the sweet spot in price and specs in the pro audio market with this workhorse line of subwoofers, midrange, and high-frequency drivers. The ODEUM series consist of two 1200W 18” subwoofers (one neodymium, one ceramic), 5 sizes and various power ratings of neodymium mid-bass, and two 1” exit compression drivers (one bolt-on, one screw-on). Upgrade, replace, or create a new pro sound system with the ODEUM series.
    We've Got Your Back
    Learn More
    Shop the Whole Odeum Series
    Dayton Audio Pro 6
    Nominal Diameter: 6.5"
    Frequency Response: 90Hz - 8.0kHz
    Shop Now
    Dayton Audio Pro 8
    Nominal Diameter: 8"
    Frequency Response: 75Hz - 5.8kHz
    Shop Now
    Dayton Audio Pro 10
    Nominal Diameter: 10"
    Frequency Response: 60Hz - 4.2kHz
    Shop Now
    Dayton Audio Pro 15
    Nominal Diameter: 15"
    Frequency Response: 40Hz - 4.5kHz
    Shop Now
    Dayton Audio Pro 18F
    Nominal Diameter: 18"
    Frequency Response: 35Hz - 1.0kHz
    Shop Now
    Dayton Audio Pro 18
    Shop Now
    Ryman 1017S
    Exit Diameter: 1"
    Frequency Response: 1kHz - 20kHz
    Shop Now
    Ryman 1017B
    Exit Diameter: 1"
    Shop Now
    Model12MB400N-8
    Part Number295-642
    UPC848791008504
    Weight13
    Nominal Diameter12"
    Power Handling (RMS)400 Watts
    Power Handling (MAX)800 Watts
    Frequency Response40 to 5,600Hz
    Sensitivity96.6dB 2.83V/1m
    Voice Coil Diameter3"
    Resonant Frequency (Fs)38Hz
    DC Resistance (Re)7.5Ω
    Voice Coil Inductance (Le)1.21mH
    Mechanical Q (Qms)7.75
    Electromagnetic Q (Qes)0.27
    Total Q (Qts)0.26
    Compliance Equivalent Volume (Vas)4.52ft³
    Mechanical Compliance of Suspension (Cms)0.323mm/N
    BL Product (BL)19.19T·m
    Diaphragm Mass Inc. Airload (Mms)54.46g
    Maximum Linear Excursion (Xmax)6.75mm
    Surface Area of Cone (Sd)494.56cm²
    Cone MaterialCoated Paper
    Surround MaterialPaper
    Voice Coil FormerFiberglass
    Magnet MaterialNeodymium
    Overall Outside Diameter12.59"
    Baffle Cutout Diameter11.49"
    Depth5.66"
    Sealed Volume0.8ft³
    Sealed F3128Hz
    Vented Volume0.9ft³
    Vented F377Hz
