  • Dayton Audio XO2W-3K 2-Way Speaker Crossover 3,000 Hz
Dayton Audio
Part #260-144
Dayton Audio
Part #260-144
Model: XO2W-3K
The Dayton Audio line of 2-way crossovers were designed using a second order (12 dB/octave) Linkwitz-Riley alignment. Dayton Audio metallized metallized polyester film capacitors are used in both the high and low-pass sections.
  • 18 gauge inductors are used to keep DC resistance to a minimum
  • Unique design feature of the low-pass section allows for use of 4 or 8 ohm woofers
  • All components are glued or fastened down to eliminate buzzing and vibrations
  • High quality blue PC board uses a back plate for added rigidity
Your Price: $21.98
MSRP: $39.99
Save $18.01 (45%)
Quantity:Qty: 1-9 $21.98/ea
Quantity:Qty: 10+$19.78/ea
177In Stock
The Dayton Audio line of 2-way crossovers were designed using a second order (12 dB/octave) Linkwitz-Riley alignment. Dayton Audio metallized polyester film capacitors are used in both the high and low pass sections. 18 gauge inductors were used to keep DC resistance to a minimum. A unique design feature of the low-pass section allows use of 4 or 8 ohm woofers, perfect for building D'Appolito style or multi woofer 2-way systems. The high pass crossover frequency is rated for an 8 ohm load. All components are glued or fastened down to eliminate buzzing and vibrations. The high quality blue PC board uses a back plate for added rigidity and eyelet holes for easy mounting. Available in a variety of crossover points. 300W power handling. Board measures: 6-1/2" W x 4-1/4" H x 1-3/8" D. Terminals are 0.205".
ModelXO2W-3K
Part Number260-144
UPC844632045158
Weight1
Crossover Type2-Way
