  • Dayton Audio DC250-8 10" Classic Woofer
Dayton Audio
Part #295-315
Dayton Audio
Part #295-315
Model: DC250-8
Choose the Dayton Audio DC250-8 Classic Series 10" woofer for use as a great replacement speaker for large format 2-way and 3-way, ported or sealed loudspeakers.
  • Best price/performance value available anywhere
  • Excellent low frequency capabilities
  • Rubber surround and vented pole piece
Your Price: $44.98
MSRP: $49.99
Save $5.01 (10%)
Quantity:Qty: 1-3 $44.98/ea
Quantity:Qty: 4+$40.48/ea
Estimated back in stock 4/11/2025
Alert Me When Available
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC250-8 10" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. Smooth frequency response and extended bass performance make this driver ideal for use in large format two-way and classic three-way loudspeaker designs. A Qts of 0.38 allows the DC250-8 to work well in both sealed and ported speaker enclosures.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
ModelDC250-8
Part Number295-315
UPC844632000263
Weight4.68
Nominal Diameter10"
Bolt Circle Diameter9.67
Power Handling (RMS)70 Watts
Power Handling (MAX)140 Watts
Frequency Response25 to 2,500Hz
Sensitivity88.4dB 2.83V/1m
Voice Coil Diameter1.38"
Resonant Frequency (Fs)24.9Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)2.63mH
Mechanical Q (Qms)3.16
Electromagnetic Q (Qes)0.44
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)3.67ft³
Mechanical Compliance of Suspension (Cms)0.61mm/N
BL Product (BL)12.64T·m
Diaphragm Mass Inc. Airload (Mms)67.5g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)343.1cm²
Cone MaterialTreated Paper
Voice Coil FormerAluminum
Overall Outside Diameter10.08"
Baffle Cutout Diameter9.21"
Depth4.44"
Sealed Volume0.7ft³
Sealed F360Hz
Vented Volume2.5ft³
Vented F329Hz
