  • Parts Express Speaker Crossover 3-Way 8 Ohm 800/5,000 Hz 100W
Part #260-210
Part #260-210
3-way crossover for speaker designed to handle 100 watts RMS program power. Crossover frequencies of 800 Hz and 5,000 Hz with 12 dB per octave roll-off into an 8 ohm load.
  • Designed to handle 100 watts RMS program power
  • Frequencies of 800 Hz and 5,000 Hz with 12 dB per octave roll-off into an 8 ohm load
Your Price: $22.98
MSRP: $39.99
Save $17.01 (43%)
Quantity:Qty: 1-9 $22.98/ea
Quantity:Qty: 10+$20.68/ea
Order in the next 0 hr 45 min to ship today. Details
93In Stock
3-way crossover for speaker designed to handle 100 watts RMS program power. Crossover frequencies of 800 Hz and 5,000 Hz with 12 dB per octave roll-off into an 8 ohm load. Dimensions: 4-3/4" W x 4" D x 1-1/8" H. Connection instructions (with crossover aligned as pictured): Top left is input positive (+), bottom left is input negative (-), bottom right is midrange positive (+), centered on the right are three output negative (-) connections, above the output negative connections is the woofer positive (+), top right is the tweeter positive (+).
Part Number260-210
UPC844632017018
Weight1.0956
Crossover Type3-Way
