  • Dayton Audio DC300-8 12" Classic Woofer
Dayton Audio
Part #295-320
Dayton Audio
Part #295-320
Model: DC300-8
Choose the Dayton Audio DC300-8 Classic Series 12" woofer for use as a great replacement speaker for large format 2-way and 3-way, ported or sealed loudspeakers.
  • Works great as a general replacement woofer
  • Excellent price/performance ratio
  • Bring those old vintage speakers back to life
  • Long lasting rubber surround increases the life of the driver
Your Price: $59.98
MSRP: $68.99
Save $9.01 (13%)
Quantity:Qty: 1-3 $59.98/ea
Quantity:Qty: 4+$49.48/ea
Order in the next 1 hr 16 min to ship today. Details
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC300-8 12" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. Smooth frequency response and extended bass performance make this driver ideal for use in large format two-way and classic three-way loudspeaker designs. A Qts of 0.33 allows the DC300-8 produce incredible low frequency extension in vented enclosures or tight response with a powerful kick in sealed enclosures.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
ModelDC300-8
Part Number295-320
UPC844632000270
Weight7.8
Nominal Diameter12"
Bolt Circle Diameter11.5
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Frequency Response25 to 2,500Hz
Sensitivity90.3dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)22.9Hz
DC Resistance (Re)6.8Ω
Voice Coil Inductance (Le)2.93mH
Mechanical Q (Qms)3.21
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)6.41ft³
Mechanical Compliance of Suspension (Cms)0.48mm/N
BL Product (BL)16.3T·m
Diaphragm Mass Inc. Airload (Mms)100.7g
Maximum Linear Excursion (Xmax)4.3mm
Surface Area of Cone (Sd)498.8cm²
Cone MaterialTreated Paper
Voice Coil FormerAluminum
Overall Outside Diameter12.07"
Baffle Cutout Diameter11"
Depth5.18"
Sealed Volume1.5ft³
Sealed F354Hz
Vented Volume3ft³
Vented F331Hz
