  • Dayton Audio DC160-8 6-1/2" Classic Woofer
Dayton Audio
Part #295-305
Dayton Audio
Part #295-305
Model: DC160-8
Choose the Dayton Audio DC160-8 Classic Series 6-1/2" woofer for use as a great replacement bookshelf speaker, midbass in 3-way designs, or even as a small subwoofer.
  • Great bang-for-the-buck driver can be used as a woofer, midbass, or even as a small subwoofer!
  • Smooth frequency response up to 2 kHz and great bass response
  • Rubber surround, aluminum voice coil, and extended bump plate
  • Low 34 Hz free-air resonance
Your Price: $29.98
MSRP: $36.99
Save $7.01 (19%)
Quantity:Qty: 1-3 $29.98/ea
Quantity:Qty: 4+$26.98/ea
Order in the next 2 hr 59 min to ship today. Details
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC160-8 6-1/2" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. You can even be use the DC160-8 as a small subwoofer! The excellent low frequency performance will amaze you.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
ModelDC160-8
Part Number295-305
UPC844632000232
Weight3.3
Nominal Diameter6-1/2"
Bolt Circle Diameter6.16
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Frequency Response30 to 4,000Hz
Sensitivity86.1dB 2.83V/1m
Voice Coil Diameter1.38"
Resonant Frequency (Fs)35.7Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)2.26mH
Mechanical Q (Qms)3.46
Electromagnetic Q (Qes)0.38
Total Q (Qts)0.34
Compliance Equivalent Volume (Vas)0.63ft³
Mechanical Compliance of Suspension (Cms)0.68mm/N
BL Product (BL)10.7T·m
Diaphragm Mass Inc. Airload (Mms)29.3g
Maximum Linear Excursion (Xmax)3.2mm
Surface Area of Cone (Sd)134.8cm²
Cone MaterialTreated Paper
Voice Coil FormerAluminum
Overall Outside Diameter6.5"
Baffle Cutout Diameter5.69"
Depth3.24"
Sealed Volume0.25ft³
Sealed F398Hz
Vented Volume0.43ft³
Vented F343Hz
