GRS 12PT-8 12" Paper Cone Professional Woofer with 3" Voice Coil 8 Ohm
- Lightweight ribbed paper cone allows high efficiency with minimal resonance
- Smooth on and off axis response up to 2,000 Hz for use in high output 2 or 3-way designs
- 3” diameter voice coil on heat resistant Kapton former easily handles up to 350 watts RMS
- Extensive venting keeps cool air flowing across the voice coil to minimize power compression
- Inductance lowering copper cap reduces distortion and extends high frequency response
- Spring-loaded push-button terminals makes wire connections quick and easy
- Foam front gasket ensures an airtight seal for rear mount installations
