  • HiVi M6N 6" Aluminum/Magnesium Midbass
HiVi
Part #297-441
HiVi
Part #297-441
Model: M6N
A shielded magnet structure allows the HiVi M6N to be incorporated easily into audio/video speaker applications.
  • Symmetrical Motor Drive (SMD) reduces distortion
  • Advanced magnesium/aluminum alloy cone provides optimal stiffness and damping
  • Hi-temp voice coil and former for high power handling
  • Magnetically shielded
  • Dynamic, accurate performance
Your Price: $35.89
MSRP: $53.99
Save $18.10 (34%)
Quantity:Qty: 1-3 $35.89/ea
Quantity:Qty: 4-9 $33.79/ea
Quantity:Qty: 10+$31.49/ea
Order in the next 4 hr 44 min to ship today. Details
70In Stock
A shielded magnet structure allows the HiVi M6N to be incorporated easily into audio/video speaker applications. The driver may be used in a small closed box as a midrange unit in a 3-way system and the good extension (50 Hz) in a vented enclosure allows for use in a 2-way, two-driver or MTM configured system.
BrandHiVi
ModelM6N
Part Number297-441
UPC844632022616
Weight6.06
Nominal Diameter6"
Bolt Circle Diameter6.65
Power Handling (RMS)45 Watts
Power Handling (MAX)90 Watts
Frequency Response46 to 8,000Hz
Sensitivity89dB 2.83V/1m
Voice Coil Diameter0.98"
Resonant Frequency (Fs)46Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)4.69
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.77ft³
Mechanical Compliance of Suspension (Cms)0.871mm/N
BL Product (BL)7.8T·m
Diaphragm Mass Inc. Airload (Mms)13.6g
Maximum Linear Excursion (Xmax)4.3mm
Surface Area of Cone (Sd)133cm²
Cone MaterialAluminum / Magnesium
Voice Coil Wire MaterialCCA
Overall Outside Diameter7"
Baffle Cutout Diameter5.313"
Depth4.0625"
Sealed Volume0.38ft³
Sealed F366.6Hz
Vented Volume0.75ft³
Vented F345.8Hz
