  • HiVi M3N 3" Aluminum / Magnesium Midbass
HiVi
Part #297-433
HiVi
Part #297-433
Model: M3N
The HiVi M3N 3" full-range speaker features a magnesium/aluminum alloy cone, stamped frame, and hi-temp voice coil and bobbin.
Your Price: $12.39
MSRP: $18.99
Save $6.60 (35%)
Quantity:Qty: 1-3 $12.39/ea
Quantity:Qty: 4-9 $12.15/ea
Quantity:Qty: 10+$11.99/ea
Estimated back in stock 1/23/2025
Alert Me When Available
A shielded magnet structure allows the HiVi M3N 3" full-range speaker to be incorporated easily into audio/video and multimedia applications. The driver may be used in a small closed box as a midrange unit in a three-way system and the good extension (97 Hz) in a vented enclosure allows for use in a 2-way two-driver or MTM configured system. The M3N also features a magnesium/aluminum alloy cone, stamped frame, and hi-temp voice coil and bobbin.
BrandHiVi
ModelM3N
Part Number297-433
UPC844632022586
Weight1.2
Nominal Diameter3"
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response100 to 8,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.78"
Resonant Frequency (Fs)91Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)4.2
Electromagnetic Q (Qes)1.03
Total Q (Qts)0.8
Compliance Equivalent Volume (Vas)0.05ft³
Mechanical Compliance of Suspension (Cms)0.82mm/N
BL Product (BL)3T·m
Diaphragm Mass Inc. Airload (Mms)2.6g
Surface Area of Cone (Sd)30cm²
Cone MaterialAluminum / Magnesium
Voice Coil Wire MaterialCCA
Overall Outside Diameter3.5"
Baffle Cutout Diameter3"
Depth2.625"
Sealed Volume0.1ft³
Sealed F398.2Hz
Vented Volume0.15ft³
Vented F373.6Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
