  • HiVi M4N 4" Aluminum / Magnesium Midbass
HiVi
Part #297-434
HiVi
Part #297-434
Model: M4N
A shielded magnet structure allows the HiVi M4N 4" full-range speaker to be incorporated easily into audio/video applications.
  • Gorgeous magnesium-alloy cone
  • Great extension for a small driver
  • Similar sound as the B4N used in the popular Overnight Sensations bookshelf speakers
Your Price: $16.29
MSRP: $19.99
Save $3.70 (19%)
Quantity:Qty: 1-3 $16.29/ea
Quantity:Qty: 4-9 $15.54/ea
Quantity:Qty: 10+$14.79/ea
Order in the next 0 hr 47 min to ship today. Details
64In Stock
A shielded magnet structure allows the HiVi M4N 4" full-range speaker to be incorporated easily into audio/video applications. The driver may be used in a small closed box as a midrange unit in a three-way system and the good extension (70 Hz) in a vented enclosure allows for use in a 2-way two-driver or MTM configured system. Stamped steel frame, magnesium/aluminum ally cone, optimized magnetic circuit, and high temperature CCAW voice coil.
BrandHiVi
ModelM4N
Part Number297-434
UPC844632022593
Weight1.32
Nominal Diameter4"
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response69 to 8,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.875"
Resonant Frequency (Fs)69Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)5.9
Electromagnetic Q (Qes)1.35
Total Q (Qts)1.08
Compliance Equivalent Volume (Vas)0.16ft³
Mechanical Compliance of Suspension (Cms)1.28mm/N
BL Product (BL)3.1T·m
Diaphragm Mass Inc. Airload (Mms)4.8g
Surface Area of Cone (Sd)53cm²
Cone MaterialAluminum / Magnesium
Voice Coil Wire MaterialCCA
Overall Outside Diameter4.55"
Baffle Cutout Diameter3.938"
Depth2.55"
Sealed Volume0.15ft³
Sealed F360.8Hz
Vented Volume0.32ft³
Vented F364Hz
