  • HiVi M3N-B 3" Damped Aluminum/Magnesium Cone Full-Range Driver
207 Questions, 343 Answers or
HiVi
Part #297-482
HiVi
Part #297-482
Model: M3N-B
The HiVi M3N-B 3" full-range speaker features a black magnesium/aluminum alloy cone, stamped frame, and hi-temp voice coil and bobbin.
Your Price: $13.98
MSRP: $24.99
Save $11.01 (44%)
Quantity:Qty: 1-3 $13.98/ea
Quantity:Qty: 4-9 $13.28/ea
Quantity:Qty: 10+$12.58/ea
Order in the next 14 hr 32 min to ship today. Details
39In Stock
A shielded magnet structure allows the HiVi M3N-B 3" full-range speaker to be incorporated easily into audio/video and multimedia applications. The driver may be used in a small closed box as a midrange unit in a three-way system and the good extension (97 Hz) in a vented enclosure allows for use in a 2-way two-driver or MTM configured system. The M3N also features a black magnesium/aluminum alloy cone, stamped frame, and hi-temp voice coil and bobbin.
BrandHiVi
ModelM3N-B
Part Number297-482
UPC848864070612
Weight1.25
Nominal Diameter3"
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response100 to 8,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.78"
Resonant Frequency (Fs)91Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)4.2
Electromagnetic Q (Qes)1.03
Total Q (Qts)0.8
Compliance Equivalent Volume (Vas)0.05ft³
Mechanical Compliance of Suspension (Cms)0.82mm/N
BL Product (BL)3T·m
Diaphragm Mass Inc. Airload (Mms)2.6g
Surface Area of Cone (Sd)30cm²
Voice Coil Wire MaterialCCA
Baffle Cutout Diameter3"
Depth2.65"
Sealed Volume0.1ft³
Sealed F398.2Hz
Vented Volume0.15ft³
Vented F373.6Hz
