  • Dayton Audio IOSUB 10" IP66 Indoor/Outdoor Subwoofer 150W Black
Dayton Audio
Part #310-026
Dayton Audio
Part #310-026
Adding low-end to your outdoor audio setup is simple with the Dayton Audio IOSUB 10" Indoor/Outdoor Subwoofer. The sub's high excursion woofer and exclusive acoustic tuning produce an exceptional bass response in a compact weather-resistant design. Perfect for adding bass to outdoor areas such as patios, pools, gardens, and landscaped areas, the IOSUB delivers exceptional performance at an affordable price.
  • Robust high excursion woofer produces astoundingly deep, clean bass for patio, pools, gardens, and porches
  • Rugged IP66 weather-resistant construction protects the sub from environmental conditions providing years of reliable use
  • Compact design allows for stealthy placement of the sub so that it unobtrusively blends into your outdoor aesthetics
  • Security features enable you to anchor the sub in location to deter potential theft
Your Price: $239.98
MSRP: $324.99
Save $85.01 (26%)
The Dayton Audio IOSUB 10" Indoor/Outdoor Subwoofer utilizes a robust high excursion polypropylene woofer with stitched rubber surround to produce a powerful yet accurate low-end to your outdoor audio system. Enclosed in a compact, easy to hide weather-resistant enclosure, the sub is the perfect choice for adding bass to patios, pools, gardens, and landscaped areas.
Ground Rattling Bass
With a robust 10" high excursion woofer, the IOSUB provides an added low-end dimension to your audio system. In combination with exclusive tuning by Dayton Audio, the woofer produces low-end down to 40 Hz with 300 watts of power. Even in a compact enclosure, the sub delivers powerful, tight, and deep bass while remaining visually unobtrusive.
Durable Weather-Resistant Construction
Built to withstand Mother Nature, the IOSUB will perform reliably year after year. The IP66 rated enclosure protects the sub from unfavorable environmental conditions thus providing flexibility for installation locations. Featuring a rugged, durable construction the sub is perfect for adding bass to outdoor areas such as pools, patios, gardens, and landscaped areas.
Affordable, Flexible Performance
Adding bass to your outdoor audio system doesn’t have to be expensive, Dayton Audio has once again delivered exceptional value at a cost-effective price tag. The high-performing, great sound IOSUB provides robust flexibility and outstanding sonic quality at half the cost of contemporaries. Take ground-rattling bass outside with the Dayton Audio IOSUB…you won't regret it but your neighbors might.
Great Sound, great price
"Couldn't have hoped for more at this price point in an outdoor sub. Sounds great in my pool area. I paired it with a Dayton SA100 amp and a pair of Dayton IO65XTW speakers. Pool time is going to sound fantastic this summer!"
Great value!!!
"Wow, for the price really excellent. Take this in context: this is for an outdoor system. (No it does compare with my multiple thousand dollar home theater sub, but neither does the price).  It is surprisingly clean and punch and super cheap compared to other outdoor subs. I paired it with a 100w sub amp and I am quite pleased. Fills in low end with little drone once you play with the crossover frequency. All is all great value."
  • Description: 10" indoor/outdoor subwoofer
  • Woofer: 10" polypropylene cone
  • Frequency response: 40-300 Hz
  • Impedance: 4 ohms
  • Low pass filter: 250 Hz 12 dB/octave (7 mH coil, 56 uF cap)
  • Power handling: 150 watts RMS/300 watts peak
  • SPL: 86 dB 2.83V/1m
  • Ingress protection rating: IP66
  • Color: Black
  • Dimensions: 12.2" x 16.5" x 16.5"
ModelIOSUB
Part Number310-026
UPC848791006012
Weight28.2
ColorBlack
ConfigurationSubwoofer
Input Rating4 ohm
Mounting StyleLandscape
Woofer Diameter10"
Special FeaturesIndoor / Outdoor-Water Resistant
