  • Dayton Audio DB8 8" Outdoor Burial Subwoofer 180W
Dayton Audio
Part #310-028
Dayton Audio
Part #310-028
The Dayton Audio DB8 8" Outdoor Burial Subwoofer gives you the ability to add discrete low end to your outdoor audio system. Featuring an 8" woofer with 400 watts of power handling, the DB8 is the ideal sub to add earth shaking bass to your garden, lawn, or patio audio setup.
  • 8" woofer with a polypropylene cone and rubber surround handles up to 400 watts ideal for adding massive low end to your outdoor audio system
  • Burial form factor keeps the sub discrete easy to hide underground
  • Rugged ABS construction ensures reliable performance year after year
Your Price: $199.98
MSRP: $354.99
Save $155.01 (44%)
Dayton Audio DB8 Outdoor Burial Subwoofer
An Effortless Addition
The Dayton Audio DB8 8" outdoor burial subwoofer gives you the ability to add discrete low end to your outdoor audio system. Utilizing an 8" woofer with a polypropylene cone and rubber surround, the DB8 delivers massive outdoor bass. With the ability to handle up to a powerful 400 watts, the DB8 provides your outdoor audio system with earth rattling low end.
High Output
The port of the DB8 extends above ground, both extending the low frequency and directing the output exactly where you need it. Extra protection is provided with an installed mesh screen on top of the port to keep the elements and critters out.
High Protection
The enclosure of the DB8 is made of high-density ABS and sealed with an extra-rugged gasket to protect the high-output woofer inside. This protection measure also guarantees the enclosure will not leak and provide the full output without any losses.
DB8 Specifications:
  • Driver: 8" polypropylene cone with rubber surround
  • Power Handling (RMS): 180 Watts
  • Power Handling (MAX): 400 Watts
  • Frequency Response: 25-300 Hz
  • Impedance:
  • SPL: 83 dB 2.83V/1m
  • Ingress Protection Rating: IPX5
  • Material: ABS
  • Dimensions: 28" H x 19.7" W x 15.6" D
  • Weight: 32.2 lbs. (each)
  • NOTE: The leads on the DB8 are color-coded for polarity. A blue wire will be the positive lead and a brown wire is the negative lead.
Shop Other Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8‑ohm bypass
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Available in 5‑1/4", 6‑1/2", and 8" versions in black and white
IOX Line
  • Passive radiator produces extended low‑end response for deep, tight bass uncharacteristic of outdoor speakers
  • Sealed IP66 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6‑1/2" and 8" versions in black and white
Pendant Line
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8‑ohm bypass
  • Suitable for indoor and outdoor installation
  • Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
    Outdoor Subs
    Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
    Shop Now
    Need Some More Help?
    Need some help with your project? Part Express's technical support staff can help answer any questions that you might have and help ensure that your speaker design and build are successful.
    Customer Service
    To enquire about an order or report an order problem:
    Email: CustomerService@Parts-Express.com
    Phone: 1-800-338-0531
    Hours:
    8 AM-6 PM Monday - Friday ET
    Closed Saturday & Sunday
    Technical Support
    To get technical information about our products:
    Email: Tech@Parts-Express.com
    Hours:
    Additional Resources
    Get Inspired and Learn From The Best
    Parts Express is a leading supplier in raw drivers, speaker components, and resources for speaker builders. Whether you are a seasoned vet or someone looking to find a new hobby, Parts Express has the gear and resources you need to complete your next project. The large community of speaker builders on our Tech Talk forum allow you to learn from some of the best in the business. For more inspiration, check out the Project Gallery which showcases a variety of designs from the speaker building community.
    ModelDB8
    Part Number310-028
    UPC848791007484
    Weight36.85
    ColorBlack
    ConfigurationSubwoofer
    Input Rating8 ohm
    Mounting StyleLandscape
    Woofer Diameter8"
    Special FeaturesIndoor / Outdoor-Water Resistant
