  • Dayton Audio IO525WT 5-1/4" 2-Way Indoor/Outdoor Speaker Pair White
Dayton Audio
Part #310-006
Dayton Audio
Part #310-006
Dayton Audio's IO525 premium indoor/outdoor speakers were designed and tuned to offer weatherproof construction, excellent sound quality, and outstanding value. Works in 70V systems or as an 8 ohm speaker.
  • Includes built-in, bypassable, multi-tap 70V transformer for commercial distributed speaker applications
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Polypropylene 5-1/4" woofer with rubber surround produces balanced, accurate bass/mid response
  • Metalized Mylar 1" dome tweeter for clean, non-fatiguing HF output
  • Installs easily on walls and ceiling; hardware included
Your Price: $169.98
MSRP: $204.99
Save $35.01 (17%)
Dayton Audio IO525WT 6-1/2" 2-Way Indoor/Outdoor Speaker
Outdoor sound this good has never been so affordable! The IO525WT speakers from Dayton Audio provide excellent sonic performance and famous Dayton Audio value in a compact, elegant package that's easy to mount anywhere -- indoors or outdoors.
    Key Specs:
  • Design: 5-1/2" 2-Way Indoor Outdoor Speaker
  • Woofer: 5-1/2" Mineral-Filled Polypropylene Cone
  • Tweeter: 1" Metalized Mylar Dome
  • Power Handling (RMS): 40 Watts @ 8 Ohms
  • Power Handling (MAX): 75 Watts @ 8 Ohms
  • Frequency Response: 55-20,000 Hz
  • Full SpecificationsManual
We Got Your Back
Learn More
Hi-Fi Full Range
Each IO525WT speaker features a mineral-filled poly cone 5-1/4" woofer and metalized Mylar 1" dome tweeter, for full-range high fidelity performance. The crossover network was computer optimized by Dayton Audio and then fine-tuned via extensive listening tests.
Consumer & Commercial Applications
Flexibility makes the IO525WT a perfect go-to speaker in any type of install. With 70V/100V transformer taps, the speaker can be used in commercial installations such as background music and paging systems in bars, hotels, conference rooms, and offices. In addition, the IO525WT includes an 8-ohm bypass option for use with consumer amps for residential applications such as pools, patios, gardens, and porches. The IO525WT is a great option for virtually any installation, residential or commercial.
Includes yoke-style mounting brackets, stainless steel hardware, and corrosion-resistant nickel plated push terminals for fast installation and wiring.
For Use Indoors & Out
The result of this effort is a detail-rich, natural sounding speaker system that is at home in dens, bedrooms, and offices as much as it is suitable for patios or beneath soffits. Thanks to rugged ABS construction and aluminum grills, these loudspeakers will keep their great looks for years.
Uses:
  • Patio, decks, gardens
  • Outdoor gathering spaces
  • Businesses, stores
  • Bars and restaurants
Shop the Whole IOX Line
IO655BT 6-1/2"
IO655WT 6-1/2"
IO525BT 5-1/4"
IO525WT 5-1/4"
  • Size: 6-1/2"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: White
  • Sold As: Pairs
  • Size: 5-1/4"
  • Color: Black
  • Sold As: Pairs
  • Size: 5-14"
  • Color: White
  • Sold As: Pairs
IO800BT 8"
IO800WT 8"
  • Size: 8"
  • Color: Black
  • Sold As: Each
  • Size: 8"
  • Color: White
  • Sold As: Each
Shop All Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8?ohm bypass
  • Available in 5?1/4", 6?1/2", and 8" versions in black and white
IOX Line
  • Passive radiator produces extended low?end response for deep, tight bass uncharacteristic of outdoor speakers
  • Sealed IP66 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6?1/2" and 8" versions in black and white
Pendant Line
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8?ohm bypass
  • Suitable for indoor and outdoor installation
  • Available in 4", 6?1/2", and 8" versions in black and white (4" only available in black)
Outdoor Subs
Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
Shop Now
Well Made
"I've had 6 of these in service for over 3 months now in a retail environment and a warehouse environment. They sound great for what they are, and are built well and include everything you need to mount and install."
- Nick S.
  • Design: 5-1/4" 2-Way Indoor Outdoor
  • Impedance: 8? / 70V
  • SPL: 85 dB 1W/1m
  • 70V Taps: 4W, 8W, 16W, 30W
  • Dimensions: 9-1/2" W x 6-3/4" D x 7-1/4" H
  • Weight: 7.05 lbs. (each)
Need Some More Help?
Need some help with your project? Part Express's technical support staff can help answer any questions that you might have and help ensure that your speaker design and build are successful.
Customer Service
To enquire about an order or report an order problem:
Email: CustomerService@Parts-Express.com
Phone: 1-800-338-0531
Hours: 8 AM–6 PM Monday – Friday ET
Closed Saturday & Sunday
Technical Support
To get technical information about our products:
Email: Tech@Parts-Express.com
Hours: 8 AM-6 PM Monday - Friday ET
Additional Resources
Get Inspired and Learn From The Best
Parts Express is a leading supplier in raw drivers, speaker components, and resources for speaker builders. Whether you are a seasoned vet or someone looking to find a new hobby, Parts Express has the gear and resources you need to complete your next project. The large community of speaker builders on our Tech Talk forum allow you to learn from some of the best in the business. For more inspiration, check out the Project Gallery which showcases a variety of designs from the speaker building community.
ModelIO525WT
Part Number310-006
UPC848791000218
Unit of MeasurePairs
Weight14.1
ColorWhite
Configuration2-way
Input Rating8 ohm|70V
Mounting StyleWall Mount
Woofer Diameter5.25"
Special FeaturesIndoor / Outdoor-Water Resistant
