  • Waterproof UV Direct Burial Silicone Filled Wire Nuts for Landscape/Outdoor Speaker Connection 20-Pack
1 Question, 1 Answer or
Part #095-520
Part #095-520
Quickly protect your outdoor wire splices with these waterproof wire nuts. UV rated plastic caps deliver long lasting protection in the harshest environments. These features make them perfect for outdoor speaker and landscape lighting wire applications.
  • UV resistant and silicone filling makes them perfect for wiring outdoor speakers and landscape lighting
  • Use them outdoors above or below ground for long-lasting connection
  • UV caps won't dry out and crack
  • 100% silicone won't harden which keeps water from reaching the bare wires
  • Easy to install without any crimping tools
  • Works with solid or stranded 22 to 12 AWG wire
  • Works great for marine applications
Your Price: $11.98
MSRP: $19.99
Save $8.01 (40%)
Quantity:Qty: 1-9 $11.98/ea
Quantity:Qty: 10+$10.78/ea
85.2In Stock
Quickly protect your outdoor wire splices with these waterproof twist-on wire connectors. UV rating delivers long lasting protection in the harshest environments. Internal silicone prevents water from getting to the bare wire. The silicon doesn't harden and the UV protected caps won't dry out and crack, which makes them ideal for outdoor speaker and landscape lighting applications.
Note: Once installed it's not recommended you pull the wires back out. Use for permanent installations.
Part Number095-520
UPC848864071251
Unit of MeasurePackages
Weight0.1
Connector TypeClosed End
Wire Gauge22-14 AWG
    MONSTER DEAL
    OF THE WEEK
    $29.98 EACH
    SAVE 25%
    Talent SB16-32 Stage Boss 32.5 ft. 16/3 Multi-Outlet Commercial Grade Extension Cord with 7 AC Sockets
