  • Dayton Audio IO800BT 8" 2-Way Indoor/Outdoor Speaker Black
Dayton Audio
Part #310-032
Dayton Audio
Part #310-032
Dayton Audio's IO800 premium indoor/outdoor speaker was designed and tuned to offer weatherproof construction, excellent sound quality, and outstanding value. Works in 70V systems or as an 8 ohm speaker.
  • Includes built-in, bypassable, multi-tap 70V transformer for commercial distributed speaker applications
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Polypropylene 8" woofer with rubber surround produces accurate mids and deep bass
  • 1" fabric dome tweeter for clean, non-fatiguing HF output
  • Installs easily on walls and ceiling; hardware included
Your Price: $169.98
MSRP: $249.99
Save $80.01 (32%)
Outdoor sound this good has never been so affordable! The IO800 speakers from Dayton Audio provide excellent sonic performance and famous Dayton Audio value in a compact, elegant package that's easy to mount anywhere -- indoors or outdoors.
  • Design: 8" 2-Way Indoor Outdoor Speaker
  • Woofer: 8" Mineral-Filled Polypropylene Woofer
  • Tweeter: 1" Fabric Dome
  • Power Handling (RMS): 65 Watts
  • Power Handling (MAX): 130 Watts
  • Frequency Response: 38-20,000 Hz
We Got Your Back
Learn More
Hi-Fi Full Range
Each IO800 speaker features a mineral-filled poly cone 8" woofer and 1" fabric dome tweeter, for full-range high fidelity performance. The crossover network was computer optimized by Dayton Audio and then fine-tuned via extensive listening tests.
Consumer & Commercial Applications
Flexibility makes the IO800BT a perfect go-to speaker in any type of install. With 70V/100V transformer taps, the speaker can be used in commercial installations such as background music and paging systems in bars, hotels, conference rooms, and offices. In addition, the IO800BT includes an 8-ohm bypass option for use with consumer amps for residential applications such as pools, patios, gardens, and porches. The IO800BT is a great option for virtually any installation, residential or commercial.
Includes yoke-style mounting brackets, stainless steel hardware, and corrosion-resistant nickel plated push terminals for fast installation and wiring.
For Use Indoors & Out
The result of this effort is a detail-rich, natural sounding speaker system that is at home in dens, bedrooms, and offices as much as it is suitable for patios or beneath soffits. Thanks to rugged ABS construction and aluminum grills, these loudspeakers will keep their great looks for years.
Uses:
  • Patio, decks, gardens
  • Outdoor gathering spaces
  • Businesses, stores
  • Bars and restaurants
Shop the Whole IOX Line
IO655BT 6-1/2"
IO655WT 6-1/2"
IO525BT 5-1/4"
IO525WT 5-1/4"
  • Size: 6-1/2"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: White
  • Sold As: Pairs
  • Size: 5-1/4"
  • Color: Black
  • Sold As: Pairs
  • Size: 5-14"
  • Color: White
  • Sold As: Pairs
IO800BT 8"
IO800WT 8"
  • Size:
  • Color:
  • Sold As:
  • Size:
  • Color:
  • Sold As:
Shop All Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8‑ohm bypass
  • Available in 5‑1/4", 6‑1/2", and 8" versions in black and white
IOX Line
  • Passive radiator produces extended low‑end response for deep, tight bass uncharacteristic of outdoor speakers
  • Sealed IP66 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6‑1/2" and 8" versions in black and white
Pendant Line
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8‑ohm bypass
  • Suitable for indoor and outdoor installation
  • Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
    Outdoor Subs
    Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
    Shop Now
    • Impedance: 8Ω / 70V
    • SPL: 87 dB 1W/1m
    • 70V Taps: 6.25W, 12.5W, 25W, 50W
    • Dimensions: 18.5" H x 11.5" W x 10" D (with bracket)
    • Weight: 7.2 lbs. (each)
    Need Some More Help?
    Need some help with your project? Part Express's technical support staff can help answer any questions that you might have and help ensure that your speaker design and build are successful.
    Customer Service
    To enquire about an order or report an order problem:
    Email: CustomerService@Parts-Express.com
    Phone: 1-800-338-0531
    Hours: 8 AM–6 PM Monday – Friday ET
    Closed Saturday & Sunday
    Technical Support
    To get technical information about our products:
    Email: Tech@Parts-Express.com
    Hours: 8 AM-6 PM Monday - Friday ET
    Additional Resources
    Get Inspired and Learn From The Best
    Parts Express is a leading supplier in raw drivers, speaker components, and resources for speaker builders. Whether you are a seasoned vet or someone looking to find a new hobby, Parts Express has the gear and resources you need to complete your next project. The large community of speaker builders on our Tech Talk forum allow you to learn from some of the best in the business. For more inspiration, check out the Project Gallery which showcases a variety of designs from the speaker building community.
    ModelIO800BT
    Part Number310-032
    UPC848791007569
    Weight16.8
    ColorBlack
    Configuration2-way
    Input Rating8 ohm|70V
    Mounting StyleWall Mount
    Woofer Diameter8"
    Special FeaturesIndoor / Outdoor
