  • Dayton Audio IO65XTW 6-1/2" IP66 Indoor/Outdoor 2-Way Speaker Pair with Radiator White
Dayton Audio
Part #310-023
Dayton Audio
Part #310-023
The Dayton Audio IO65XTW 6-1/2" IP66 Indoor/Outdoor Speaker Pair brings unprecedented audio fidelity outdoors. With both 70V/100V taps and 8-ohm bypass, the weather-resistant IO65XTW speaker can be used for both commercial and residential installs. Dayton Audio has once again delivered extreme versatility, outstanding value, and exceptionally great sonic performance at an affordable price.
  • Passive Radiator Design: Delivers deep, tight bass for a richer audio experience in both indoor and outdoor environments.
  • Versatile Applications: Suitable for commercial (70V/100V systems) and residential (8-ohm bypass) setups, making it ideal for bars, hotels, patios, and more.
  • IP66-Rated Enclosure: Weather-resistant ABS enclosure and aluminum grill protect against harsh outdoor conditions, ensuring durability.
  • High-Quality Audio Components: Features a 6-1/2" polypropylene woofer and 1" soft dome tweeter for balanced sound.
  • Flexible Installation Options: Comes with mounting brackets that allow for vertical or horizontal installation with easy pivoting for optimal sound direction.
  • Powerful Performance: Handles up to 100 watts (MAX) for clear, full-range sound with a frequency response of 45-20,000 Hz.
  • Elegant Design: Stylish, contemporary appearance in white blends seamlessly with any décor, indoors or out.
Your Price: $269.98
MSRP: $349.99
Save $80.01 (23%)
Dayton Audio IO65XTW 6-1/2" Indoor/Outdoor 2-Way Speaker with Radiator White
Utilizing a passive radiator, the Dayton Audio IO65XT Indoor/Outdoor Speakers delivers a surprising amount of low-end while remaining suitable for outdoor use. The IO65XT is suitable for use in both commercial and consumer applications with 70V/100V taps as well as an 8-ohm bypass. The flexible nature of the speakers make them perfect for patios, pools, gardens, offices, bars, and hotels.
Key Specs:
  • Design: 6-1/2" 2-Way Indoor Outdoor Speaker
  • Woofer: 6-1/2" Polypropylene Cone
  • Tweeter: 1" Soft Dome
  • Power Handling (RMS): 50 Watts @ 8 Ohms
  • Power Handling (MAX): 100 Watts @ 8 Ohms
  • Frequency Response: 42-20,000 Hz
We Got Your Back
Incredible Bass Response
The IO65XT challenges the notion that outdoor speakers lack in low-end response. Without sacrificing durability, the IO65XT is able to produce extended bass by using a passive radiator. The passive radiator design allows the speaker to provide a surprisingly deep, tight bass response while keeping the enclosure small. The superb bass and natural, smooth high-end create an enjoyable listening experience no matter where installed, indoors and out.
Consumer & Commercial Applications
Flexibility makes the IO65XT a perfect go-to speaker in any type of install. With 70V/100V transformer taps, the speaker can be used in commercial installations such as background music and paging systems in bars, hotels, conference rooms, and offices. In addition, the IO65XT includes an 8-ohm bypass option for use with consumer amps for residential applications such as pools, patios, gardens, and porches. The IO65XT is a great option for virtually any installation, residential or commercial.
70V/100V Transformer with 8 Ohm Bypass
For Use Indoors & Out
Flaunting an IP66 ABS enclosure, the IO65XT is perfect for outdoor use. The water-resistant build allows for the speaker to be used in outdoor applications, even in unfavorable environmental conditions. Rugged and durable build quality ensures a long life for years of enjoying great sounding audio.
Uses:
  • Larger outdoor gathering spaces
  • Pools and theme parks
  • Entertainment venues
  • Warehouses, shipping centers
Installer's Dream
Included brackets allow for the speaker to be mounted either vertically or horizontally with the ability to pivot making installation simple and quick. Since the speakers are easy to install and a breeze to position, the IO65XT saves both installation time and money allowing for adherence even to the tightest budget..
Shop the Whole IOX Line
IO65XBT 6-1/2"
IO65XWT 6-1/2"
IO8XTB 8"
IO8XTW 8"
  • Size: 6-1/2"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: White
  • Sold As: Pairs
  • Size: 8"
  • Color: Black
  • Sold As: Single
  • Size: 8"
  • Color: White
  • Sold As: Single
Shop All Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8‑ohm bypass
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Available in 5‑1/4", 6‑1/2", and 8" versions in black and white
IOX Line
  • Passive radiator produces extended low‑end response for deep, tight bass uncharacteristic of outdoor speakers
  • Sealed IP66 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6‑1/2" and 8" versions in black and white
Pendant Line
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8‑ohm bypass
  • Suitable for indoor and outdoor installation
  • Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
Outdoor Subs
Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
Shop Now
Impressive Sound
"Installed these in a small restaurant lounge. Impressive sounding with plenty of low end as well as crisp clear highs without any tuning yet."
- Ivan B
  • Design: 6-1/2" 2-Way Indoor Outdoor with Passive Radiator
  • Impedance: 8Ω / 70V
  • SPL: 86 dB 1W/1m
  • 70V Taps: 5W, 10W, 20W, 40W
  • Ingress Protection Rating: IP66
  • Dimensions: 11.25" W x 7.9" D x 7.7" H
  • Weight: 7.6 lbs. (each)
Need Some More Help?
Need some help with your project? Part Express's technical support staff can help answer any questions that you might have and help ensure that your speaker design and build are successful.
Customer Service
To enquire about an order or report an order problem:
Email: CustomerService@Parts-Express.com
Phone: 1-800-338-0531
Hours:
8 AM–6 PM Monday – Friday ET
Closed Saturday & Sunday
Technical Support
To get technical information about our products:
Email: Tech@Parts-Express.com
Hours 8 AM-6 PM Monday - Friday ET
Additional Resources
Get Inspired and Learn From The Best
Parts Express is a leading supplier in raw drivers, speaker components, and resources for speaker builders. Whether you are a seasoned vet or someone looking to find a new hobby, Parts Express has the gear and resources you need to complete your next project. The large community of speaker builders on our Tech Talk forum allow you to learn from some of the best in the business. For more inspiration, check out the Project Gallery which showcases a variety of designs from the speaker building community.
ModelIO65XTW
Part Number310-023
UPC848791005992
Unit of MeasurePairs
Weight18.65
ColorWhite
Configuration2-way
Input Rating8 ohm|70V|100V
Mounting StyleWall Mount
Woofer Diameter6.5"
Special FeaturesIndoor / Outdoor-Water Resistant
