  • GRS 5PF-8 5-1/4" Paper Cone Foam Surround Woofer
GRS
Part #292-405
GRS
Part #292-405
Model: 5PF-8
The GRS 5PF-8 5-1/4" woofers feature a poly-laminate coated cone and a foam surround. They are ideally suited for all sealed-box speaker applications.
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
Your Price: $8.98
MSRP: $11.99
Save $3.01 (25%)
Quantity:Qty: 1-3 $8.98/ea
Quantity:Qty: 4+$8.08/ea
The GRS 5PF-8 5-1/4" woofers feature a poly-laminate coated cone and a foam surround. They are ideally suited for all sealed-box speaker applications. Thanks to their carefully optimized parameters, GRS 5PF-8 5-1/4" poly-laminated paper cone woofers offer a high degree of compatibility when used as replacement speakers—they also provide excellent performance in new projects, too.
BrandGRS
Model5PF-8
Part Number292-405
UPC844632088452
Weight1.15
Nominal Diameter5-1/4"
Power Handling (RMS)90 Watts
Power Handling (MAX)180 Watts
Frequency Response90 to 8,000Hz
Sensitivity85dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)162Hz
DC Resistance (Re)7.3Ω
Voice Coil Inductance (Le)0.5mH
Mechanical Q (Qms)5.96
Electromagnetic Q (Qes)3.09
Total Q (Qts)2.04
Compliance Equivalent Volume (Vas)0.05ft³
Mechanical Compliance of Suspension (Cms)0.16mm/N
BL Product (BL)3.8T·m
Diaphragm Mass Inc. Airload (Mms)6.1g
Surface Area of Cone (Sd)75.2cm²
Cone MaterialTreated Paper
Surround MaterialFoam
Overall Outside Diameter5.0625"
Baffle Cutout Diameter4.75"
Depth2.3125"
Sealed Volume0.18ft³
Sealed F390Hz
