  • GRS 12PF-8 12" Paper Cone Foam Surround Woofer
GRS
Part #292-412
GRS
Part #292-412
Model: 12PF-8
GRS 12PF-8 12" poly-laminated paper cone woofers are perfect for use in sealed-box home theater and music systems.
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
Your Price: $19.98
MSRP: $25.99
Save $6.01 (23%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$17.98/ea
Order in the next 3 hr 27 min to ship today. Details
GRS 12PF-8 12" poly-laminated paper cone woofers are perfect for use in sealed-box home theater and music systems. Thanks to their carefully optimized parameters, GRS 12PF-8 12" poly-laminated paper cone woofers offer a high degree of compatibility when used as replacement speakers—they also provide excellent performance in new projects, too.
BrandGRS
Model12PF-8
Part Number292-412
UPC844632088490
Weight3.85
Nominal Diameter12"
Power Handling (RMS)120 Watts
Power Handling (MAX)240 Watts
Frequency Response35 to 5,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)38Hz
DC Resistance (Re)7.4Ω
Voice Coil Inductance (Le)1.2mH
Mechanical Q (Qms)6.49
Electromagnetic Q (Qes)2.76
Total Q (Qts)1.93
Compliance Equivalent Volume (Vas)3.97ft³
Mechanical Compliance of Suspension (Cms)0.29mm/N
BL Product (BL)6.3T·m
Diaphragm Mass Inc. Airload (Mms)61.8g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)524.3cm²
Cone MaterialTreated Paper
Overall Outside Diameter12"
Baffle Cutout Diameter11.0625"
Depth4.69"
Sealed Volume2ft³
Sealed F345Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
