  • Dayton Audio RS150-8 6" Reference Woofer
Dayton Audio
Part #295-354
Dayton Audio
Part #295-354
Model: RS150-8
Dayton Audio Reference Series RS150-8 6" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
  • One of the lowest distortion, highest resolution driver series available
  • Low-distortion high-excursion motor system with two short-circuit paths
  • Compliant suspension and rigid black anodized aluminum cone for strong bass performance
  • Heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug
  • Designed and engineered in the USA
Your Price: $54.98
MSRP: $64.99
Save $10.01 (15%)
Quantity:Qty: 1-3 $54.98/ea
Quantity:Qty: 4+$48.74/ea
Order in the next 1 hr 58 min to ship today. Details
The Dayton Audio Reference Series was conceived with one goal in mind—low distortion. Each speaker was carefully designed and optimized to offer the highest performance with the lowest distortion levels. At the same time, by focusing on features that contribute to sound quality and eliminating unnecessary frills, the drivers offer value unparalleled in the industry. Dayton Audio Reference Series RS150-8 6" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
ModelRS150-8
Part Number295-354
UPC844632088742
Weight3.55
Nominal Diameter6"
Bolt Circle Diameter5.43
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Frequency Response47 to 4,200Hz
Sensitivity88.7dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)47.8Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.55mH
Mechanical Q (Qms)1.66
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.34
Compliance Equivalent Volume (Vas)0.59ft³
Mechanical Compliance of Suspension (Cms)1.63mm/N
BL Product (BL)5.59T·m
Diaphragm Mass Inc. Airload (Mms)7.4g
Surface Area of Cone (Sd)85cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter5.91"
Baffle Cutout Diameter4.78"
Depth2.89"
# Mounting Holes6
Sealed Volume0.11ft³
Sealed F3128Hz
Vented Volume0.35ft³
Vented F361Hz
