  • Dayton Audio RS150-4 6" Reference Woofer 4 Ohm
Dayton Audio
Part #295-372
Dayton Audio
Part #295-372
Model: RS150-4
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold terminals.
  • 4 ohm impedance is perfect for series pairs in MTMs and center channel speakers
  • Excellent car audio midrange/midbass
  • High-end low-distortion motor with two shorting paths to reduce inductance
Your Price: $49.98
MSRP: $58.99
Save $9.01 (15%)
Quantity:Qty: 1-3 $49.98/ea
Quantity:Qty: 4+$44.98/ea
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold terminals.
ModelRS150-4
Part Number295-372
UPC844632054235
Weight2.8001
Nominal Diameter6"
Bolt Circle Diameter5.43
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Frequency Response48 to 4,000Hz
Sensitivity91.8dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)45.1Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)0.34mH
Mechanical Q (Qms)1.96
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)0.579ft³
Mechanical Compliance of Suspension (Cms)1.62mm/N
BL Product (BL)4.1T·m
Diaphragm Mass Inc. Airload (Mms)7.7g
Maximum Linear Excursion (Xmax)4.4mm
Surface Area of Cone (Sd)85cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter5.91"
Baffle Cutout Diameter4.78"
Depth2.76"
# Mounting Holes6
Sealed Volume0.12ft³
Sealed F3125Hz
Vented Volume0.28ft³
Vented F364Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
