  • Parts Express Speaker L-Pad Attenuator 100W Mono 3/8" Shaft 16 Ohm
Part #260-261
Part #260-261
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series and parallel, keeping impedance at a constant 16 ohm load. This 100 watt RMS L-pad is designed to be used with 16 ohm loads, features a 3/8" shaft length, and comes with mounting hardware.
  • Add volume controls to any speaker
  • Great for speaker design tweaking
  • Maintains 16 ohm impedance
  • Mounting hardware included
Your Price: $15.98
MSRP: $19.99
Save $4.01 (20%)
Quantity:Qty: 1-9 $15.98/ea
Quantity:Qty: 10+$14.38/ea
520In Stock
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series. At the same time, a counter-resistance is placed in parallel with the driver to maintain a constant impedance which allows the original crossover design to be used. L-pads are to be placed in between the amplifier and speaker, or in between the crossover and driver. This particular L-pad is rated at 100 watts RMS, is designed to be used with 16 ohm loads, features a 3/8" shaft length, and comes with mounting hardware, faceplate, and volume control knob.
Dimensions: 2.5" diameter, 1-1/8" depth.
L-Pad Instruction Diagram
Part Number260-261
UPC844632018480
Weight0.708
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
