Dayton Audio RS150P-4A 6" Reference Paper Woofer 4 Ohm
Dayton Audio
Part #295-563
Dayton Audio
Part #295-563
Model: RS150P-4A
Dayton Audio Reference Series paper cone drivers combine class-leading low distortion performance with the use of a proprietary cone blend. Now with a flatter frequency response and smoother high frequency roll-off allowing for extended bandwidth and easier crossover integration.
- Now with improved frequency response for easier crossover integration
- Three-part paper composite diaphragm featuring paper, Kevlar, and glass fibers
- Low-distortion motor, 6-hole cast frame, rubber surround, and solid aluminum phase plug
- Perfect for use as a woofer, midwoofer, or dedicated midrange driver
- 90.3 dB sensitivity and 4.4 mm of excursion
