Timpano Audio TPT-HL11-25 1" Screw-On Plastic Horn 60 x 60 1-3/8"-18 TPI
Timpano Audio
Part #294-3350
Timpano Audio
Part #294-3350
Model: TPT-HL11-25
If you have little depth to work with but need wide dispersion and high output, Timpano Audio's TPT-HL11-25 is the horn you need. The 60 x 60 dispersion pattern will easily fill a wide area and at under 3" deep this horn can fit almost anywhere.
- Standard 1-3/8"-18 TPI screw-on mount fits many popular compression drivers
- Lightweight reinforced ABS construction to support heavy drivers
- 60 x 60 dispersion pattern to fill any space with sound
- Under 3" deep for installation is extremely shallow spaces
