  • JBL Selenium D250-X GW 1" Phenolic Horn Driver 1-3/8"-18 TPI
Selenium
Part #264-204
Selenium
Part #264-204
Model: D250-X GW
The JBL Selenium D250-X horn driver offers outstanding performance for midrange reproduction in professional PA systems. Its 1-3/8"-18 TPI threaded exit is compatible with many popular screw-on horns.
  • Low distortion and extreme clarity in the critical mid or vocal range
  • Phenolic diaphragm for smooth response and high reliability
  • Standard 1-3/8"-18 TPI screw mount
  • Popular driver for Leslie rotating speakers and guitar "talk boxes" too!
  • Sold individually
Your Price: $49.99
MSRP: $74.99
Save $25.00 (33%)
The JBL Selenium D250-X is an affordable compression driver with a lightweight, strong phenolic diaphragm designed for midrange reproduction in indoor/outdoor background sound systems and small PA systems alike. The D250-X's 1" threaded exit fits all Selenium horns with model numbers ending in 25. High temperature wire used for the voice coil is wound on a Kapton former to withstand high operating temperatures. The nearly indestructible phenolic diaphragm structure allows for easy, cost-effective replacement, in the unlikely event of failure.
Specifications: • Power handling: 150 watts (w/xover, 500 Hz, 12 dB/octave)/200 watts (w/xover, 1,000 Hz, 12 dB/octave) • VCdia: 2" • Impedance: 8 ohms • Frequency response: 400-9,000 Hz (no crossover) • SPL: 107 dB 1W/1M • Magnet weight: 11.7 oz. • Dimensions: 4.41" dia. x 3" D • RPD250-X replacement diaphragm available, see Related Items tab.
BrandSelenium
ModelD250-X GW
Part Number264-204
Weight2.7
Diaphragm MaterialPhenolic
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)150 Watts
