  • PRV Audio D280Ti-S 1" Titanium Horn Driver 8 Ohm 1-3/8"-18 TPI
PRV Audio
Part #294-2827
PRV Audio
Part #294-2827
Model: D280Ti-S
Upgrade your PA speaker cabinets today using PRV Audio's amazing D280-Ti compression driver. High output and smooth frequency response allows you to use this horn driver in almost any high output audio application: pro, home, or car. Standard 1-3/8"-18 TPI threading.
  • Kapton® former and titanium diaphragm for neutral sound
  • Designed for high frequency use: 1,300-20,000 Hz
  • High 109 dB sensitivity
  • Standard 1-3/8"-18 TPI threading
  • Spring-loaded speaker terminals
Your Price: $39.91
MSRP: $49.89
Save $9.98 (20%)
PRV Audio's D280-Ti 1" pure titanium compression driver offers a surprisingly smooth, neutral sound not normally found in titanium compression drivers at this price point. In fact, the D280-Ti competes with drivers costing up to three times as much! The 1" exit and 1-3/8"-18 TPI threading makes this the perfect upgrade horn driver for many popular professional audio speaker cabinets, and the linear frequency response from 1,300 to 20,000 Hz allows it to be used in high output home audio and car audio systems.
The pure titanium diaphragm is attached to a 1-3/4" diameter copper voice coil with Kapton® former for the lowest possible moving mass without sacrificing power handling. This allows for an amazing 109 dB of output with only 1 watt of input power (2.83V), when measured at one meter, for use in even the loudest of environments!
Specifications: • Power handling: 80 watts RMS with recommended crossover of 1,800 Hz, 12 dB/octave slope • VCdia: 1.75" • Impedance: 8 ohms • Frequency response: 1,300-20,000 Hz • SPL: 109 dB 2.83V/1m • Dimensions: 4.52" diameter x 2" depth (2.56" with threads) • Net weight: 3.31 lbs. • Replacement diaphragm available (please see Related Items).
BrandPRV Audio
ModelD280Ti-S
Part Number294-2827
UPC799928733854
Weight3.5
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)80 Watts
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
