  • GRS 10SW-4HE 10" High Excursion Subwoofer 4 Ohm
GRS
Part #292-818
GRS
Part #292-818
Model: 10SW-4HE
The versatile 10SW-4HE 10” high excursion subwoofer from GRS is designed to produce excellent low frequency extension in a variety of designs. Suitable for both sealed and vented enclosures, this driver the ideal replacement or upgrade for your existing subwoofers with worn out or blown drivers. Featuring extensive venting, rubber surround, high temperature voice coil, low Fs, and 11 mm of excursion the 10SW-4HE is built for remarkable bass response on a budget.
  • High excursion and low Fs to produce powerful low frequency output
  • 2” voice coil on a thick aluminum former to handle up to 200 watts RMS
  • Venting under the spider, through the pole piece, and in the magnetic gap for excellent heat dissipation
  • Durable reinforced paper cone with rubber surround produces reliable and consistent performance
  • Extended frame and bumped back plate allow ample clearance for high excursion
Your Price: $54.98
MSRP: $89.99
Save $35.01 (39%)
Quantity:Qty: 1-3 $54.98/ea
Quantity:Qty: 4+$49.48/ea
Order in the next 0 hr 16 min to ship today. Details
Engineered for extended low frequency response and flexibility
The GRS 10SW-4HE 10” high excursion subwoofer from GRS is an ideal replacement driver for existing subwoofer systems or an excellent choice for new economical designs. Capable of producing powerful bass response in both sealed and vented designs, the 10SW-4HE is suitable as a drop-in replacement for most existing 10” subwoofers.
Key Specs:
  • Nominal Diameter: 10"
  • Power Handling (RMS): 200W
  • Power Handling (MAX): 400W
  • Impedance: 4 Ω
  • Frequency Response: 26-500Hz
  • Sensitivity: 87.5dB 2.83V/1m
  • Voice Coil Diameter: 2"
  • Maximum Linear Excursion: 11mm
Frequency Response & Impedance Curve
the GRS 10SW-4HE has a bass-centric response from 20Hz up to 800Hz and is highly efficient within its passband. This efficiency and a low QTS lends itself well to both vented and sealed subwoofers for incredibly deep bass from an 10-inch driver.
Bass-worthy construction
Extensive venting through the frame, pole piece, and magnetic gap dissipates excess heat to keep power compression to a minimum, even when driven hard for long periods. The rigid paper cone is supported by a large diameter spider and rubber surround to keep excursion linear while providing reliable performance. With a high temperature 2” voice coil wound on a thick aluminum former the 10SW-4HE can comfortably handle up to 200 watts RMS of power.
Shop all GRS High Excursion Subwoofers
GRS 8SW-4HE
Nominal Diameter: 8"
Frequency Response: 32-700Hz
Shop Now
GRS 12SW-4HE
Nominal Diameter: 12"
Frequency Response: 20-1,000Hz
Shop Now
GRS 15SSW-4HE
Nominal Diameter: 15"
Frequency Response: 15-1,000Hz
Shop Now
BrandGRS
Model10SW-4HE
Part Number292-818
UPC848864070476
Weight10.6
Nominal Diameter10"
Bolt Circle Diameter9.64
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Frequency Response26 to 500Hz
Sensitivity87.5dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)25.2Hz
DC Resistance (Re)3.8Ω
Voice Coil Inductance (Le)3mH
Mechanical Q (Qms)4
Electromagnetic Q (Qes)0.57
Total Q (Qts)0.5
Compliance Equivalent Volume (Vas)2.14ft³
Mechanical Compliance of Suspension (Cms)0.36mm/N
BL Product (BL)10.8T·m
Diaphragm Mass Inc. Airload (Mms)110.7g
Maximum Linear Excursion (Xmax)11mm
Surface Area of Cone (Sd)346.4cm²
Cone MaterialCoated Paper
Voice Coil FormerAluminum
Overall Outside Diameter10.11"
Baffle Cutout Diameter9.18"
Depth5.15"
Sealed Volume1ft³
Sealed F343Hz
Vented Volume2ft³
Vented F325Hz
