GRS 15SSW-4HE 15" High Excursion Super Subwoofer 4 Ohm
- High excursion and low Fs to produce powerful low frequency output
- Dual spider suspension for high excursion
- 2.5” voice coil on a thick aluminum former to handle up to 300 watts RMS
- Venting under the spider, through the pole piece, and in the magnetic gap for excellent heat dissipation
- Over 12mm of linear one-way X-MAX
- Extended frame and bumped back plate allow ample clearance for high excursion
- Durable reinforced paper cone with rubber surround produces reliable and consistent performance
- Price:$199.98 Part #295-168
We'll send you an email when GRS 15SSW-4HE 15" High Excursion Super Subwoofer 4 Ohm is back in stock or available for preorder.
