GRS 12SW-4HE 12" Paper Cone Rubber Surround High Excursion Subwoofer 4 Ohm
- High excursion and low Fs to produce powerful low frequency output
- 4-layer 2” voice coil on a thick aluminum former to handle up to 250 watts RMS
- Venting under the spider, through the pole piece, and in the magnetic gap for excellent heat dissipation
- Durable reinforced paper cone with rubber surround produces reliable and consistent performance
- Extended frame and bumped back plate allow ample clearance for high excursion
Only 20 In Stock
We'll send you an email when GRS 12SW-4HE 12" Paper Cone Rubber Surround High Excursion Subwoofer 4 Ohm is back in stock or available for preorder.
