  • Dayton Audio DCS255-4 10" Classic Subwoofer 4 Ohm
Dayton Audio
Part #295-202
Dayton Audio
Part #295-202
Model: DCS255-4
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses.
  • Sturdy stamped steel frame
  • Vented pole piece and bumped back plate
  • Inductance-reducing copper pole piece cap
  • Treated non-pressed paper/Kevlar cone with rubber surround
  • 4-layer VC with polyimide former
  • Great for home and automotive applications
  • Five year warranty
Your Price: $84.98
MSRP: $123.99
Save $39.01 (31%)
Quantity:Qty: 1-3 $84.98/ea
Quantity:Qty: 4+$84.22/ea
Order in the next 3 hr 17 min to ship today. Details
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses. The drivers feature a vented pole piece with copper cap, bumped back plate for improved excursion capability, Kevlar reinforced cone with rubber half-roll surround, and a high-temperature 4-layer copper voice coil wound on a polyimide former.
ModelDCS255-4
Part Number295-202
UPC844632080661
Weight10.45
Nominal Diameter10"
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Frequency Response31 to 200Hz
Sensitivity91dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)37.7Hz
DC Resistance (Re)3.45Ω
Voice Coil Inductance (Le)1.8mH
Mechanical Q (Qms)7.42
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)1.13ft³
Mechanical Compliance of Suspension (Cms)0.19mm/N
BL Product (BL)12.6T·m
Diaphragm Mass Inc. Airload (Mms)95.5g
Maximum Linear Excursion (Xmax)8.3mm
Surface Area of Cone (Sd)346.4cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter10.16"
Baffle Cutout Diameter9.13"
Depth5.54"
Sealed Volume0.58ft³
Sealed F375Hz
Vented Volume1.8ft³
Vented F330Hz
