  • Dayton Audio RSS315HO-44 12" Reference Series HO DVC Subwoofer
Dayton AudioPart # 295-467
Model: RSS315HO-44
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion.
  • Dual 4 ohm voice coils
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting-ring motor for ultra-low distortion
  • 4-layer coil for high power handling
  • Parameters optimized for small enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $249.98
MSRP: $295.99
Save $46.01 (16%)
Quantity:Qty: 1-3 $249.98/ea
Quantity:Qty: 4+ $230.55/ea
Only 12 In Stock More due any day
We'll send you an email when Dayton Audio RSS315HO-44 12" Reference Series HO DVC Subwoofer is back in stock or available for preorder.
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. The High Output (HO) drivers are optimized for automotive applications and equalized high-power home subwoofers.
ModelRSS315HO-44
Part Number295-467
UPC844632087714
Weight25.4
Nominal Diameter12"
Power Handling (RMS)700 Watts
Power Handling (MAX)1400 Watts
Frequency Response20 to 500Hz
Sensitivity84.6dB 2.83V/1m
Voice Coil Diameter2.58"
Resonant Frequency (Fs)21.5Hz
DC Resistance (Re)6.5Ω
Voice Coil Inductance (Le)3.17mH
Mechanical Q (Qms)3.7
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)2.165ft³
Mechanical Compliance of Suspension (Cms)0.17mm/N
BL Product (BL)26.5T·m
Diaphragm Mass Inc. Airload (Mms)327.7g
Maximum Linear Excursion (Xmax)14mm
Surface Area of Cone (Sd)507.1cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter11.1"
Depth5.75"
Sealed Volume0.6ft³
Sealed F346Hz
Vented Volume1.4ft³
Vented F326Hz
