  • Dayton Audio RSS315HFA-8 12" Reference Series HF Subwoofer 8 Ohm
Dayton Audio
Part #295-445
Dayton Audio
Part #295-445
Model: RSS315HFA-8
Dayton Audio's Reference Series RSS315HFA-8 12" subwoofer utilizes the same low-distortion design as the rest of the series, but provides an 8 ohm alternative for increased connection and impedance-loading options.
  • Extensively vented motor eliminates power compression and allows quiet excursion
  • Lighter-weight black anodized aluminum cone minimizes moving mass
  • 2-layer coil for reduced back EMF
  • Triple shorting-ring motor for ultra-low distortion
  • Optimized for large enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $229.98
MSRP: $285.99
Save $56.01 (20%)
Quantity:Qty: 1-3 $229.98/ea
Quantity:Qty: 4+$211.48/ea
Order in the next 11 hr 10 min to ship today. Details
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of the RSS315HFA-8 12" driver is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three magnetic short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose this High Fidelity (HF) version for home speaker systems when your priority is clean, low bass and you are not restricted by cabinet size.
ModelRSS315HFA-8
Part Number295-445
UPC844632088681
Weight24.5
Nominal Diameter12"
Power Handling (RMS)400 Watts
Power Handling (MAX)700 Watts
Frequency Response25 to 1,500Hz
Sensitivity85.7dB 2.83V/1m
Voice Coil Diameter2.58"
Resonant Frequency (Fs)22.2Hz
DC Resistance (Re)6.5Ω
Voice Coil Inductance (Le)1.56mH
Mechanical Q (Qms)2.5
Electromagnetic Q (Qes)0.54
Total Q (Qts)0.45
Compliance Equivalent Volume (Vas)3.43ft³
Mechanical Compliance of Suspension (Cms)0.27mm/N
BL Product (BL)18T·m
Diaphragm Mass Inc. Airload (Mms)194g
Maximum Linear Excursion (Xmax)14.3mm
Surface Area of Cone (Sd)506.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter11.1"
Depth5.75"
Sealed Volume1.5ft³
Sealed F339Hz
Vented Volume2.5ft³
Vented F325Hz
