  • Dayton Audio RSS315HO-4 12" Reference Series HO Subwoofer 4 Ohm
Dayton Audio
Part #295-466
Dayton Audio
Part #295-466
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting ring motor for ultra-low distortion
  • 4-layer coil for high power handling
  • Optimized parameters for small enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $229.98
MSRP: $272.99
Save $43.01 (16%)
Quantity:Qty: 1-3 $229.98/ea
Quantity:Qty: 4+$211.48/ea
Estimated back in stock 6/27/2025
Alert Me When Available
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high output version for automotive applications or for equalized high-power home subwoofers.
The Dayton Audio RSS315HO-4 is used in the following kits:
Powered Dayton Audio Reference 12" Subwoofer Kit with Dual Passive Radiators & 500 Watt DSP Plate Amp
For high output and low extension, this 500 watt 12" subwoofer kit is an excellent choice. Thanks to the passive radiator assisted design, this subwoofer is just a 16" cube, but can match the output capability of much larger designs. In addition, the included Dayton Audio SPA500DSP 500 watt amplifier provides plenty of power, but more importantly, the customizable on board DSP provides flexibility and control you will not find on any other subwoofer in this price range.
View kit
Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Bundle
This superior subwoofer cabinet is CNC-machined for precise panels and is specifically built for use with the Dayton Audio RSS315HO-4 and a plate amplifier with bass boost. Save over $25 off the original retail price when you purchase this bundle.
View kit
ModelRSS315HO-4
Part Number295-466
UPC844632006944
Weight25
Nominal Diameter12"
Power Handling (RMS)700 Watts
Power Handling (MAX)1400 Watts
Frequency Response26 to 600Hz
Sensitivity90.5dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)26.2Hz
DC Resistance (Re)3.2Ω
Voice Coil Inductance (Le)1.75mH
Mechanical Q (Qms)3.63
Electromagnetic Q (Qes)0.33
Total Q (Qts)0.31
Compliance Equivalent Volume (Vas)1.89ft³
Mechanical Compliance of Suspension (Cms)0.15mm/N
BL Product (BL)20T·m
Diaphragm Mass Inc. Airload (Mms)251g
Maximum Linear Excursion (Xmax)12.3mm
Surface Area of Cone (Sd)514.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter11.1"
Depth5.75"
Sealed Volume0.5ft³
Sealed F367Hz
Vented Volume1.5ft³
Vented F329Hz
