  • Dayton Audio RSS315HF-4 12" Reference Series HF Subwoofer 4 Ohm
Dayton Audio
Part #295-464
Dayton Audio
Part #295-464
The Dayton Audio Reference Series subwoofer speakers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Lightweight black anodized aluminum cone for rigidity and lower moving mass
  • Triple shorting ring motor for ultra-low distortion
  • 2-layer coil for reduced back EMF
  • Suitable for sealed or vented enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $219.98
MSRP: $272.99
Save $53.01 (19%)
Quantity:Qty: 1-3 $219.98/ea
Quantity:Qty: 4+$206.98/ea
As with the rest of the Dayton Audio Reference Series speakers, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion for the Reference Series RSS315HF-4 12" subwoofer speaker. The black anodized cone, rubber surround, and custom basket give this driver and the rest of the Reference Series a unique, high-end look. Choose the high fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
ModelRSS315HF-4
Part Number295-464
UPC844632006937
Weight25
Nominal Diameter12"
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response23 to 1,000Hz
Sensitivity90.3dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)24.2Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)0.96mH
Mechanical Q (Qms)2.83
Electromagnetic Q (Qes)0.45
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)2.97ft³
Mechanical Compliance of Suspension (Cms)0.23mm/N
BL Product (BL)13.99T·m
Diaphragm Mass Inc. Airload (Mms)188g
Maximum Linear Excursion (Xmax)14.3mm
Surface Area of Cone (Sd)514.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter12.36"
Baffle Cutout Diameter11.1"
Depth5.75"
Sealed Volume1ft³
Sealed F349Hz
Vented Volume2.1ft³
Vented F327Hz
