  • Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm
Dayton Audio
Part #295-204
Dayton Audio
Part #295-204
Model: DCS305-4
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses.
  • Sturdy stamped steel frame
  • Vented pole piece and bumped back plate
  • Inductance-reducing copper pole piece cap
  • Treated non-pressed paper/Kevlar cone with rubber surround
  • 4-layer VC with polyimide former
  • Great for home and automotive applications
  • Five year warranty
Your Price: $99.98
MSRP: $142.99
Save $43.01 (30%)
Quantity:Qty: 1-3 $99.98/ea
Quantity:Qty: 4+$89.55/ea
Estimated back in stock 5/30/2025
Alert Me When Available
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses. The drivers feature a vented pole piece with copper cap, bumped back plate for improved excursion capability, Kevlar reinforced cone with rubber half-roll surround, and a high-temperature 4-layer copper voice coil wound on a polyimide former.
ModelDCS305-4
Part Number295-204
UPC844632080678
Weight13.3
Nominal Diameter12"
Bolt Circle Diameter11.59
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response23 to 200Hz
Sensitivity90.5dB 2.83V/1m
Voice Coil Diameter2.57"
Resonant Frequency (Fs)24.2Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)2.06mH
Mechanical Q (Qms)5.07
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)3.25ft³
Mechanical Compliance of Suspension (Cms)0.27mm/N
BL Product (BL)13.7T·m
Diaphragm Mass Inc. Airload (Mms)160g
Maximum Linear Excursion (Xmax)9.3mm
Surface Area of Cone (Sd)498.8cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter12.05"
Baffle Cutout Diameter10.83"
Depth6.02"
Sealed Volume1ft³
Sealed F355Hz
Vented Volume3.1ft³
Vented F324Hz
