  • Dayton Audio DCS165-4 6-1/2" Classic Subwoofer 4 Ohm
Dayton Audio
Part #295-198
Dayton Audio
Part #295-198
Capable of impressive low end when installed in enclosures of less than 0.5 cubic feet, the DCS165-4 6-1/2" subwoofer from Dayton Audio's Classic Series is the perfect low cost solution for compact low frequency designs.
  • 4-layer VC with polyimide former allows high power handling
  • Vented pole piece and bumped back plate provide plenty of VC travel with minimal compression
  • Copper pole piece cap minimizes inductance
  • Rigid non-pressed treated paper/Kevlar cone with rubber surround
  • Great for home and automotive applications
Your Price: $49.98
MSRP: $72.99
Save $23.01 (32%)
Quantity:Qty: 1-3 $49.98/ea
Quantity:Qty: 4+$48.25/ea
Dayton Audio's rugged DCS165-4 6-1/2" subwoofer has all of the performance-enhancing attributes you would expect from a larger high-output subwoofer. With a vented pole piece and 4 ohm, 4-layer voice coil, this driver can handle up 100 watt RMS. The non-pressed paper cone is reinforced with Kevlar to increase stiffness, which promotes linear travel through the limits of its excursion. In addition, the pole piece includes a copper cap that keeps inductance to a minimum. The DCS165-4 driver is ideal for use in small multimedia speakers, portable speakers, or even automotive systems where space is at a minimum.
The Dayton Audio DCS165-4 is used in the following kits:
Dayton Audio 6-1/2" Down Firing Active Mini Subwoofer Kit with 2.1 Channel Amplifier
This compact active subwoofer kit is perfect for powering a compact 2.1 channel speaker system. The Dayton Audio DCS165-4 6-1/2" subwoofer is driven with 60 watts RMS for powerful output and incredible low frequency extension. The Lepai LP210PA amplifier also has 2 x 30 watt RMS outputs to power your left and right speakers. This kit is the perfect start to building your own amazingly convenient self-contained 2.1 channel system.
View Kit
Dayton Audio 6-1/2" Down Firing Passive Mini Subwoofer Kit
With an elegant compact enclosure, this 6-1/2" down-firing subwoofer kit is a great addition to any small stereo or home theater. Using a Dayton Audio DCS165-4 woofer in a vented down-firing configuration, this kit will fit low-key into any décor or under a desk to add high quality bass response and extension to your system.
View kit
ModelDCS165-4
Part Number295-198
UPC848791001901
Weight4.85
Nominal Diameter6-1/2"
Power Handling (RMS)100 Watts
Power Handling (MAX)200 Watts
Frequency Response36 to 1,100Hz
Sensitivity87.4dB 2.83V/1m
Voice Coil Diameter1.51"
Resonant Frequency (Fs)35.7Hz
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)1.43mH
Mechanical Q (Qms)6.62
Electromagnetic Q (Qes)0.36
Total Q (Qts)0.34
Compliance Equivalent Volume (Vas)0.42ft³
Mechanical Compliance of Suspension (Cms)0.5mm/N
BL Product (BL)9.15T·m
Diaphragm Mass Inc. Airload (Mms)39.5g
Surface Area of Cone (Sd)124.7cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter6.57"
Baffle Cutout Diameter5.62"
Depth3.25"
Sealed Volume0.25ft³
Sealed F3101Hz
Vented Volume0.4ft³
Vented F338Hz
