  • Dayton Audio DCS205-4 8" Classic Subwoofer 4 Ohm
Dayton Audio
Part #295-200
Dayton Audio
Part #295-200
Model: DCS205-4
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses.
  • Sturdy stamped steel frame
  • Vented pole piece and bumped back plate
  • Inductance-reducing copper pole piece cap
  • Treated non-pressed paper/Kevlar cone with rubber surround
  • 4-layer VC with polyimide former
  • Great for home and automotive applications
  • Five year warranty
Your Price: $69.98
MSRP: $84.99
Save $15.01 (18%)
Quantity:Qty: 1-3 $69.98/ea
Quantity:Qty: 4+$63.68/ea
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses. The drivers feature a vented pole piece with copper cap, bumped back plate for improved excursion capability, Kevlar reinforced cone with rubber half-roll surround, and a high-temperature 4-layer copper voice coil wound on a polyimide former.
ModelDCS205-4
Part Number295-200
UPC844632080654
Weight6.65
Nominal Diameter8"
Bolt Circle Diameter7.8
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Frequency Response30 to 200Hz
Sensitivity88.6dB 2.83V/1m
Voice Coil Diameter1.51"
Resonant Frequency (Fs)32.3Hz
DC Resistance (Re)3.9Ω
Voice Coil Inductance (Le)1.78mH
Mechanical Q (Qms)6.28
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)0.95ft³
Mechanical Compliance of Suspension (Cms)0.42mm/N
BL Product (BL)10.7T·m
Diaphragm Mass Inc. Airload (Mms)57.7g
Maximum Linear Excursion (Xmax)8.8mm
Surface Area of Cone (Sd)213.8cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter8.19"
Baffle Cutout Diameter7.09"
Depth4.23"
Sealed Volume0.35ft³
Sealed F380Hz
Vented Volume1.2ft³
Vented F331Hz
