  • Dayton Audio 4" Compact Pendant/Landscape Speaker 70V/100V/8 Ohm White WP40XTW
NEW Dayton Audio 4" Compact Pendant/Landscape Speaker 70V/100V/8 Ohm White WP40XTW
Dayton Audio
Part #310-091
Dayton Audio
Part #310-091
The Dayton Audio WP40XTW 4" Compact Pendant/Landscape Speaker is a versatile solution for high-quality indoor and outdoor audio. Its durable IP66-rated ABS enclosure ensures reliable performance in any environment, while the built-in passive radiator delivers exceptional bass response uncommon in pendant speakers. With flexible mounting options and 70V/100V or 8-ohm compatibility, this speaker adapts seamlessly to commercial or residential installations, offering outstanding sound clarity in a compact, stylish design.
  • Compact Design: 4" size fits seamlessly into indoor or outdoor settings.
  • Passive Radiator: Enhances bass performance for deeper, richer audio.
  • Durable Construction: IP66 weather-resistant ABS plastic for reliable outdoor use.
  • Flexible Mounting: Pendant, wall, and landscape mounting options included.
  • Versatile Compatibility: Integrated 70V/100V transformer with 8-ohm bypass for multiple setups.
  • Enhanced Audio Performance: 80–20,000 Hz frequency response with 20W RMS power handling.
  • Stylish Finish: Sleek white enclosure suits any aesthetic, from modern to classic.
NEW $99.98
MSRP: $149.00
Save $49.02 (33%)
Order in the next 3 hr 22 min to ship today. Details
The Dayton Audio WP40XTW Indoor/Outdoor Multi-Purpose Speaker is designed to deliver exceptional audio performance in any setting. Featuring a 2-way coaxial design with a robust 4" woofer and a precise 3/4" tweeter, it provides clear and balanced sound. Its IP66-rated weather-resistant ABS plastic construction ensures durability in outdoor environments, while its sleek, modern design seamlessly integrates into indoor spaces, making it both functional and stylish.
Versatile for Commercial and Residential Installs
The Dayton Audio WP40TW is a highly versatile speaker designed for both commercial and residential audio installations. Featuring an integrated 70/100V transformer with multiple tap settings, it offers exceptional flexibility for professional setups. For added versatility, it also includes an 8-ohm bypass, making it compatible with standard amplifiers. The WP40TW stands out with its high-quality audio performance, thanks to its 4" woofer and a built-in passive radiator, which enhance low-end response for rich, full sound. Housed in a discreet, compact enclosure, this speaker is the ideal choice for delivering exceptional sound quality in any environment, whether indoors or outdoors.
           Pendant Mount
             Wall Mount
       Landscape Mount
For ultimate flexibility, the Dayton Audio pendant indoor/outdoor speaker line offers multiple installation options, including pendant mounting, wall mounting, and landscape mounting. Designed to withstand the elements, these speakers feature durable, weather-resistant ABS plastic construction, ensuring long-lasting performance in any environment. Whether you're enhancing an outdoor patio, a commercial venue, or an indoor space, Dayton Audio pendant speakers provide reliable, high-quality sound with versatile mounting configurations to suit your specific needs.
Bass Radiator for Extended Bass Response
The Dayton Audio WP40XTW stands out with its built-in passive radiator, delivering extended bass response rarely found in pendant-mount speakers. This innovative feature allows the WP40XTW to reach low frequencies as deep as 80 Hz, significantly outperforming sealed pendant speakers of similar size, which typically only reach around 100 Hz. Ideal for both commercial and residential audio setups, the WP40XTW ensures a richer, more immersive sound experience in a compact, stylish design.
Pendant Mount
The Dayton Audio WP40XTW includes versatile mounting hardware designed for secure and easy installation. A specialized end cap protects the transformer tap selection and Phoenix wire connector, ensuring a clean and professional look. Additionally, an integrated eye bolt allows for safe hanging using a steel safety cable, making this speaker a reliable choice for pendant mounting in both indoor and outdoor audio setups.
Wall Mount
In addition to pendant mounting, the Dayton Audio WP40XTW features a ball joint mount for seamless vertical and horizontal axis adjustments, allowing precise positioning on walls or ceiling structures. This versatile mounting option ensures optimal sound dispersion, making it ideal for both commercial and residential audio applications. Enhance your audio setup with flexible installation options tailored to your space.
Landscape Mount
Finally, the Dayton Audio WP40XTW features a ball joint mount that securely connects to a durable landscape-style stake, ensuring robust support for outdoor in-ground installations. This innovative design provides stable positioning in gardens, yards, or landscaped areas, delivering premium audio performance while seamlessly blending into any outdoor environment. Ideal for elevating outdoor entertainment, this speaker offers dependable performance and versatile mounting options tailored for any setup.
Frequency Response80 - 20,000 Hz
Sensitivity
84 dB
Potential Output99 dB
Power Handling40W max (20W RMS)
Recommended Power Amplifier5 - 20 W
8 ohm
Woofer4" Graphite
Tweeter3/4" Silk Dome
Enclosure Type2-way Passive Radiator
Crossover Frequency4 kHz
Weight (each)
4.65 lbs. (2.11 kg)
Dimensions9.25 in x 5.875 in. (235 x 147.8 mm)
What's in the Box:
  • WPX Pendant Speaker
  • Back Cover
  • Top Cover
  • Eyebolt and Nut
  • Hanging Cable with Carabiner
  • Mounting Hardware
  • Landscape Mount
  • Base Plate
  • Wall Mount Bracket
  • Manual
Need Some More Help?
Need some help with your project? Part Express's technical support staff can help answer any questions that you might have and help ensure that your speaker design and build are successful.
Customer Service
To enquire about an order or report an order problem:
Email: CustomerService@Parts-Express.com
Phone: 1-800-338-0531
Hours: 8 AM–6 PM Monday – Friday ET
Closed Saturday & Sunday
Technical Support
To get technical information about our products:
Email: Tech@Parts-Express.com
Hours 8 AM-6 PM Monday - Friday ET
Additional Resources
Get Inspired and Learn From The Best
Parts Express is a leading supplier in raw drivers, speaker components, and resources for speaker builders. Whether you are a seasoned vet or someone looking to find a new hobby, Parts Express has the gear and resources you need to complete your next project. The large community of speaker builders on our Tech Talk forum allow you to learn from some of the best in the business. For more inspiration, check out the Project Gallery which showcases a variety of designs from the speaker building community.
ModelWP40XTW
Part Number310-091
UPC848791010675
Weight6.39
Input Rating20
Mounting StyleSuspended / Pendant
Woofer Diameter4"
