  • 35A Barrier Terminal Block 6 Position Dual Row Screws 12 Pitch with Cover and Black Jumper
NEW 35A Barrier Terminal Block 6 Position Dual Row Screws 12 Pitch with Cover and Black Jumper
Part #090-813
Part #090-813
Double row barrier strip made from heavy-duty thermoplastic. Clear plastic cover and 35 amp current rating make it great for automotive power distribution. Includes a black jumper bar for quick single input with at least six outputs.
  • Made with heavy-duty UL 94-2 flame rated plastic for durability and safety
  • Nickel plated copper plates provide great connectivity
  • Snap-on clear plastic cover helps prevent accidental short circuits
  • One 0.18" (4.5 mm) mounting hole on each side 3.15" (80 mm) apart for a secure hold
  • Includes a red jumper bar which prevents having to make jumper wires and identifies polarity
NEW $2.98
MSRP: $4.99
Save $2.01 (40%)
Quantity:Qty: 1-9 $2.98/ea
Quantity:Qty: 10+$2.68/ea
Easily Ground Several Devices
Use this Heavy-Duty Double Row Barrier Strip as your go-to solution for efficiently powering multiple automotive accessories or home electronics from a single power source! This versatile terminal strip is designed to streamline your wiring process, making it both effective and manageable.
Car Hookups
To begin, connect all six screws on one side of the terminal strip to the jumper bar. This setup will allow you to run a ground wire directly to the metal frame or the negative battery terminal from the same side. By doing this, you will transform the opposite side of the strip into six ground terminals, ready to power various accessory items—just be sure their total amperage does not exceed 35 amps.
Take pride in your automotive and home wiring work and enjoy the ease and efficiency that the Heavy-Duty Double Row Barrier Strip brings to your projects! You’re making a smart choice that will simplify your wiring tasks and enhance the performance of your automotive home electronic accessories.
Specifications: • Dimensions: 91.5 mm (3.6") L x 30 mm (1.18") W x 19 mm (0.75") H • Individual terminal gap: 10.22 mm (0.4") • Pitch: 12 mm (0.47") • Screws: M4 • Max voltage: 600 V • Max current: 35A • Max temperature: 110° C (230° F) • Poles: 6.
Part Number090-813
UPC848864079066
Weight0.15
