  • foamPRO 4" Textured Roller Refill 2 Pack
foamPRO
Part #260-117
foamPRO
Part #260-117
Create a professional looking textured finish when applying ExoHyde or DuraTex with these 4" textured roller refills from foamPRO. The compact size is perfect for smaller projects and getting into tight spaces. These rollers are durable and easy to clean so you can use this roller over and over again.
  • Creates a textured finish when applying ExoHyde or DuraTex to cabinets and cases
  • Cleans quickly and easily with water to use over and over again
  • Compact 4" roller is perfect for smaller projects and tight spots
  • Holds ample paint for a rugged high build coating
Your Price: $4.98
MSRP: $5.99
Save $1.01 (17%)
Quantity:Qty: 1-3 $4.98/ea
Quantity:Qty: 4+$4.73/ea
foamPRO's 4" textured roller 2-pack refill makes it easy to create a professional looking textured finish when applying ExoHyde or DuraTex cabinet coating. These rollers will hold ample paint to make it easy to apply a single high build coat with excellent coverage and durability. At only 4" long these rollers are the perfect option for smaller projects and getting a textured finish into tight spaces. Durable and easy to clean, these foamPRO rollers can be used over and over again.
This foamPRO 4" roller refill fits the foamPRO 4" roller handle.
BrandfoamPRO
Part Number260-117
UPC042224000695
