  • ExoHyde Pro Grade Textured Protective Speaker Cabinet Coating Quart - Black
ExoHyde
Part #260-2100
ExoHyde
Part #260-2100
Give your speaker cabinets a durable and professional textured finish with ExoHyde Protective Coating. Exohyde’s thick consistency and low drying time makes it easy to create attractive textures that will hide minor imperfections and withstand nicks, chips, scratches, and even moisture.
  • Paint and primer in one for an easy one coat application
  • Dries to a hard and resilient finish that withstands scuffs, scratches, and even moisture
  • Extremely low Volatile Organic Compounds (VOC), safe to apply indoors
  • Create a variety of textures with different application techniques
  • One quart of Exohyde can cover 25 to 30 square feet
Your Price: $34.98
MSRP: $49.98
Save $15.00 (30%)
Quantity:Qty: 1-3 $34.98/ea
Quantity:Qty: 4+$32.98/ea
Order in the next 18 hr 59 min to ship today. Details
ExoHyde Protective Coating is an easy to apply low VOC paint that provides superior adhesion to most surfaces and dries to a hard, resilient finish for a durable and weather resistant coating. ExoHyde's thick consistancy and fast drying time makes it easy to create a variety of textures with a very attractive finish. Thanks to the superior adhesion properties, no primer coat is necessary making the application a simple one step process. Originally designed as a professional finish for speaker enclosures, this paint can be used in a variety of situations.
Application of Exohyde is extremely easy. For surface preparation, just fill any pits and voids with putty or wood filler, sand all surfaces smooth, and remove any dust. Then, apply a heavy coat of ExoHyde to achieve the texture you want. The recommended foamPRO foam texture rollers will create a consistent texture with the look and durability of an expensive professional finish. One coat is usually all that is needed for complete coverage. However, you can use multiple coats to increase the overall texture, durability, and water resistance.
Since ExoHyde is water soluble when wet, cleanup is as easy as can be. Simply rinse brushes or rollers with water after application and they can be reused many times. Once dry, ExoHyde is extremely water resistant and very difficult to remove which allows you to clean any dirty finished surfaces with soap and water.
One quart of Exohyde can cover an area of 25 to 30 square feet in a single coat.
Notes: • Stir Exohyde thoroughly before use and occasionally during prolonged usage to prevent pigment from settling to the bottom of the can.
• Application over primer is not recommended, Exohyde is a self priming paint and is not compatible with certain primers. If you plan on using a separate primer then apply on a sample piece first to ensure compatibility.
ExoHyde pro grade textured protective speaker cabinet coating is also available in a gallon size for larger or multiple projects.
BrandExoHyde
Part Number260-2100
UPC848864062761
Weight3
